Home » Eclipse Projects » Plugin Development Environment (PDE) » Plugin Development unresolved 'org.eclipse.ui'
Plugin Development unresolved 'org.eclipse.ui' [message #1838952] Wed, 10 March 2021 05:45 Go to next message
Hi!
I Can't move a plugin project from Eclipse 2019-06(4.12 w. openjdk 1.8.0) to Eclipse 2020-12 (4.18 w. openjdk 11.0.10).
Going into Windows/Preferences/Plug-in Development/Target Platform/Running Platform/Edit: I can't find 'org.eclipse.ui'.
It is listed in 2019-06.
I tried creating a new Platform but none of the populating alternative gave me more plugins.
I have 5501 plugins in my old system but only 574 in my new system (not so populated jet...)
Any idea what's next to do?
Running on Fedora 33
Here is an example
1. Start Eclipse
2. Open a new empty Workspace.
3. Create a project: Plug-in Development/Plug-in Project, Next, <Name>, Next, Next
4. Create a plug-in using a template: Hello, World Command, Finish.
5. Open Perspective.
In MANIFEST.MF/Dependencies 'org.eclipse.ui' unresolved (red x)
Errors (17 items)
Description Resource Path Location Type
AbstractHandler cannot be resolved to a type SampleHandler.java /Test/src/test/handlers line 10 Java Problem
Bundle 'org.eclipse.ui' cannot be resolved MANIFEST.MF /Test/META-INF line 6 Plug-in Problem
ExecutionEvent cannot be resolved to a type SampleHandler.java /Test/src/test/handlers line 13 Java Problem
ExecutionException cannot be resolved to a type SampleHandler.java /Test/src/test/handlers line 13 Java Problem
HandlerUtil cannot be resolved SampleHandler.java /Test/src/test/handlers line 14 Java Problem
IWorkbenchWindow cannot be resolved to a type SampleHandler.java /Test/src/test/handlers line 14 Java Problem
MessageDialog cannot be resolved SampleHandler.java /Test/src/test/handlers line 15 Java Problem
The import org.eclipse cannot be resolved SampleHandler.java /Test/src/test/handlers line 3 Java Problem
The import org.eclipse cannot be resolved SampleHandler.java /Test/src/test/handlers line 4 Java Problem
The import org.eclipse cannot be resolved SampleHandler.java /Test/src/test/handlers line 5 Java Problem
The import org.eclipse cannot be resolved SampleHandler.java /Test/src/test/handlers line 6 Java Problem
The import org.eclipse cannot be resolved SampleHandler.java /Test/src/test/handlers line 7 Java Problem
The import org.eclipse cannot be resolved SampleHandler.java /Test/src/test/handlers line 8 Java Problem
Unknown extension point: 'org.eclipse.ui.bindings' plugin.xml /Test line 25 Plug-in Problem
Unknown extension point: 'org.eclipse.ui.commands' plugin.xml /Test line 6 Plug-in Problem
Unknown extension point: 'org.eclipse.ui.handlers' plugin.xml /Test line 18 Plug-in Problem
Unknown extension point: 'org.eclipse.ui.menus' plugin.xml /Test line 34 Plug-in Problem
/Thanks
[Updated on: Wed, 10 March 2021 11:21] by Moderator
Re: Plugin Development unresolved 'org.eclipse.ui' [message #1839064 is a reply to message #1838952] Fri, 12 March 2021 04:07 Go to previous message
This is not happening in Eclipse' build, it's something with Fedora.
Dose anyone know how 'Target Definitions' gets populate?
In the Windows/Preferences/Plug-in Development/Target Platform/Running Platform/Add: there are 4 options.
Two of them "Default: Default target for the running plattform" and "Template:" will build a new list.
But how is this put together and what could be wrong with Fedora.
Is the list built by scanning or is it predefined in a file and if so which one?
Previous Topic:Eclipse e4 application wizard
Next Topic:Custom toolbar for plugin perspective
Current Time: Mon Jul 21 07:44:38 EDT 2025
Powered by FUDForum. Page generated in 0.04260 seconds
