Home » Newcomers » Newcomers » FrameworkEvent ERROR(ICE not starting after double click and gives the following error message in log file.)
FrameworkEvent ERROR [message #1839037] |
Thu, 11 March 2021 11:14  |
!SESSION 2021-03-11 13:30:23.418 -----------------------------------------------
eclipse.buildId=unknown
java.version=15.0.2
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_GB
Framework arguments: -product org.eclipse.ice.client.rcp.sdk_product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.ice.client.rcp.sdk_product
!ENTRY org.eclipse.ice.materials 4 0 2021-03-11 13:30:30.455
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Error starting module.
at org.eclipse.osgi.container.Module.doStart(Module.java:590)
at org.eclipse.osgi.container.Module.start(Module.java:449)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1600)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
Caused by: java.lang.NoClassDefFoundError: javax/xml/bind/JAXBException
at java.base/java.lang.Class.getDeclaredConstructors0(Native Method)
at java.base/java.lang.Class.privateGetDeclaredConstructors(Class.java:3296)
at java.base/java.lang.Class.getConstructor0(Class.java:3501)
at java.base/java.lang.Class.newInstance(Class.java:626)
at org.eclipse.osgi.internal.framework.BundleContextImpl.loadBundleActivator(BundleContextImpl.java:758)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:711)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:932)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309)
at org.eclipse.osgi.container.Module.doStart(Module.java:581)
... 8 more
Caused by: java.lang.ClassNotFoundException: javax.xml.bind.JAXBException cannot be found by org.eclipse.ice.materials_2.2.0.201702201939
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:461)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:522)
... 17 more
Root exception:
... 17 more
!ENTRY org.eclipse.equinox.ds 1 0 2021-03-11 13:30:30.458
!MESSAGE Could not bind a reference of component org.eclipse.january.geometry.model.factory. The reference is: Reference[name = IGeometryImporterService, interface = org.eclipse.january.geometry.model.importer.IGeometryImporterService, policy = dynamic, cardinality = 0..n, target = null, bind = register, unbind = null]
!ENTRY org.eclipse.emf.ecore 2 0 2021-03-11 13:30:30.540
!MESSAGE Both 'org.eclipse.january.geometry.xtext.iges' and 'org.eclipse.january.geometry.xtext.vtk' register a package for 'http://www.eclipse.org/january/geometry/xtext/IGES'
!ENTRY org.eclipse.january.geometry.xtext.vtk 2 0 2021-03-11 13:30:30.566
!MESSAGE [SCR] Found components with duplicated names! Details:
Component1 : Component[
name = org.eclipse.january.geometry.xtext.obj
activate = activate
deactivate = deactivate
modified =
configuration-policy = optional
factory = null
autoenable = true
immediate = false
implementation = org.eclipse.january.geometry.xtext.vtk.service.VTKGeometryImporterService
state = Unsatisfied
properties =
serviceFactory = false
serviceInterface = [org.eclipse.january.geometry.model.importer.IGeometryImporterService]
references = null
located in bundle = org.eclipse.january.geometry.xtext.vtk_0.1.1.201610251608 [475]
Component2: Component[
activate = activate
modified =
factory = null
autoenable = true
immediate = false
implementation = org.eclipse.january.geometry.xtext.obj.service.OBJGeometryImporterService
state = Unsatisfied
properties =
references = null
located in bundle = org.eclipse.january.geometry.xtext.obj_0.1.1.201610251608 [472]
!ENTRY org.eclipse.osgi 4 0 2021-03-11 13:30:31.079
!MESSAGE Application error
!STACK 1
org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:386)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultHeadlessContext(E4Application.java:490)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:504)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:203)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:632)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:64)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:564)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
Caused by: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375)
... 23 more
Caused by: java.lang.ClassNotFoundException: javax.annotation.PostConstruct cannot be found by org.eclipse.e4.core.di_1.6.1.v20160712-0927
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:410)
... 25 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2021-03-11 13:30:31.085
!STACK 0
java.lang.NoClassDefFoundError: javax/annotation/PreDestroy
at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:426)
at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:154)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:78)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:111)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:74)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:176)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:106)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:139)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156)
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476)
at org.eclipse.osgi.container.Module.doStop(Module.java:634)
at org.eclipse.osgi.container.Module.stop(Module.java:498)
at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:202)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:165)
at java.base/java.lang.Thread.run(Thread.java:832)
Caused by: java.lang.ClassNotFoundException: javax.annotation.PreDestroy cannot be found by org.eclipse.e4.core.di_1.6.1.v20160712-0927
... 21 more
!SESSION 2021-03-11 13:36:13.036 -----------------------------------------------
java.version=15.0.2
!ENTRY org.eclipse.ice.materials 4 0 2021-03-11 13:36:21.264
!STACK 0
... 8 more
... 17 more
Root exception:
... 17 more
!ENTRY org.eclipse.equinox.ds 1 0 2021-03-11 13:36:21.268
!ENTRY org.eclipse.emf.ecore 2 0 2021-03-11 13:36:21.376
!ENTRY org.eclipse.january.geometry.xtext.vtk 2 0 2021-03-11 13:36:21.408
activate = activate
modified =
factory = null
autoenable = true
immediate = false
state = Unsatisfied
properties =
references = null
activate = activate
modified =
factory = null
autoenable = true
immediate = false
state = Unsatisfied
properties =
references = null
!ENTRY org.eclipse.osgi 4 0 2021-03-11 13:36:22.146
!STACK 1
... 23 more
... 25 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2021-03-11 13:36:22.153
!STACK 0
... 21 more
!SESSION 2021-03-11 13:36:32.630 -----------------------------------------------
java.version=15.0.2
!ENTRY org.eclipse.ice.materials 4 0 2021-03-11 13:36:36.482
!STACK 0
... 8 more
... 17 more
Root exception:
... 17 more
!ENTRY org.eclipse.equinox.ds 1 0 2021-03-11 13:36:36.486
!ENTRY org.eclipse.emf.ecore 2 0 2021-03-11 13:36:36.608
!ENTRY org.eclipse.january.geometry.xtext.vtk 2 0 2021-03-11 13:36:36.644
activate = activate
modified =
factory = null
autoenable = true
immediate = false
state = Unsatisfied
properties =
references = null
activate = activate
modified =
factory = null
autoenable = true
immediate = false
state = Unsatisfied
properties =
references = null
!ENTRY org.eclipse.osgi 4 0 2021-03-11 13:36:37.366
!STACK 1
... 23 more
... 25 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2021-03-11 13:36:37.372
!STACK 0
... 21 more
!SESSION 2021-03-11 13:37:13.291 -----------------------------------------------
java.version=15.0.2
!ENTRY org.eclipse.ice.materials 4 0 2021-03-11 13:37:16.822
!STACK 0
... 8 more
... 17 more
Root exception:
... 17 more
!ENTRY org.eclipse.equinox.ds 1 0 2021-03-11 13:37:16.826
!ENTRY org.eclipse.emf.ecore 2 0 2021-03-11 13:37:16.927
!ENTRY org.eclipse.january.geometry.xtext.vtk 2 0 2021-03-11 13:37:16.952
activate = activate
modified =
factory = null
autoenable = true
immediate = false
state = Unsatisfied
properties =
references = null
activate = activate
modified =
factory = null
autoenable = true
immediate = false
state = Unsatisfied
properties =
references = null
!ENTRY org.eclipse.osgi 4 0 2021-03-11 13:37:17.627
!STACK 1
... 23 more
... 25 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2021-03-11 13:37:17.631
!STACK 0
... 21 more
!SESSION 2021-03-11 13:37:30.655 -----------------------------------------------
java.version=15.0.2
!ENTRY org.eclipse.ice.materials 4 0 2021-03-11 13:37:32.857
!STACK 0
... 8 more
... 17 more
Root exception:
... 17 more
!ENTRY org.eclipse.equinox.ds 1 0 2021-03-11 13:37:32.864
!ENTRY org.eclipse.emf.ecore 2 0 2021-03-11 13:37:32.972
!ENTRY org.eclipse.january.geometry.xtext.vtk 2 0 2021-03-11 13:37:33.003
activate = activate
modified =
factory = null
autoenable = true
immediate = false
state = Unsatisfied
properties =
references = null
activate = activate
modified =
factory = null
autoenable = true
immediate = false
state = Unsatisfied
properties =
references = null
!ENTRY org.eclipse.osgi 4 0 2021-03-11 13:37:33.655
!STACK 1
Attachment: .log
(Size: 86.65KB, Downloaded 148 times)
Current Time: Thu Jul 24 21:09:54 EDT 2025
Powered by FUDForum. Page generated in 0.08296 seconds
