Home » Modeling » Epsilon » Problem using append in EGX
Problem using append in EGX [message #1838695] Wed, 03 March 2021 14:16 Go to next message
I'm trying to use EGX to generate code in one file using several coordinated rules. When I try to use append I get these errors on the last two lines:
Line: 30, Column: 1, Reason: no viable alternative at input 'append'
Line: 31, Reason: mismatched input: '}'
I had used append about a year ago with no problems. Now it is giving me trouble, even with the code that used to work.
rule tf transform f : Foo{
	template : "template1.egl"
	target : "test.txt"
	append : true
Thanks for the help.
Re: Problem using append in EGX [message #1838697 is a reply to message #1838695] Wed, 03 March 2021 14:51 Go to previous messageGo to next message
Hi Nick,
This seems to be a regression that was not caught by our test suite. Thank you for reporting this and we'll look into it as soon as possible.
Dimitris
Re: Problem using append in EGX [message #1838698 is a reply to message #1838697] Wed, 03 March 2021 15:00 Go to previous messageGo to next message
I've filed https://bugs.eclipse.org/bugs/show_bug.cgi?id=571665 to keep track of this.
Re: Problem using append in EGX [message #1838771 is a reply to message #1838698] Thu, 04 March 2021 14:55 Go to previous messageGo to next message
Fixed in https://git.eclipse.org/c/epsilon/org.eclipse.epsilon.git/commit/?id=69b4922f3eef0649e1378d2e1d4a583a758bec87
Thanks again for reporting this.
Re: Problem using append in EGX [message #1838788 is a reply to message #1838771] Thu, 04 March 2021 21:43 Go to previous message
thank you for fixing this so quickly!
Previous Topic:Code generation
Next Topic:Mylyn Driver
Current Time: Tue Sep 09 18:07:03 EDT 2025
Powered by FUDForum. Page generated in 0.04110 seconds
