Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » Problems on replace(FORTE crashes when deploying Systems with "replace" or "replace all")
Problems on replace [message #1838607] Tue, 02 March 2021 06:07 Go to next message
I am running FORTE on an STM32MP157-based Board and I want to use it in a way, that it runs continuously from startup.
The problem I am facing is, that FORTE starts acting weird when I replace a running System with a different one.
I get a message saying:
WARNING: T#9664266793842: [CStringDictionary::insert] String to insert was empty
WARNING: T#9664267829310: [CStringDictionary::insert] String to insert was empty
ERROR: T#9664325360185: [CDeviceExecution] Couldn't start new event chain becaus e the event source was null
Is it a known Problem?
Right now I have to either kill and restart forte or reboot the Board.
Thanks in advance
Re: Problems on replace [message #1838609 is a reply to message #1838607] Tue, 02 March 2021 06:57 Go to previous messageGo to next message
the first two warnings are known and you can ignore them. But they are also not the source of your problem. What concerns me more is your last message. Do you have any special SIFBs with event sources?
Alois
Re: Problems on replace [message #1838611 is a reply to message #1838609] Tue, 02 March 2021 07:25 Go to previous messageGo to next message
yes I have some SIFBs for the BACnet Communication protocol.(Subscribe COV functionality)
I had to implement custom SIFBs for this because of some required extra-functions but I am still using the FDSelecthandler and the FBs inherit from CEventSourceFB.
BR
Niklas
Re: Problems on replace [message #1838613 is a reply to message #1838611] Tue, 02 March 2021 07:56 Go to previous messageGo to next message
in your destructor of this SIFBs or in the kill/stop handling are you deinitialilsing your communication? You can have a look in the CommFB and BaseCommFB fbs.
BR,
Alois
[Updated on: Tue, 02 March 2021 07:57] by Moderator
Re: Problems on replace [message #1838751 is a reply to message #1838613] Thu, 04 March 2021 08:48 Go to previous messageGo to next message
that was the root of the problem. I edited the destructor and everything is working fine now.
Thanks for your help.
BR,
Niklas
Re: Problems on replace [message #1838772 is a reply to message #1838751] Thu, 04 March 2021 15:06 Go to previous message
Happy to support.
Previous Topic:loop current status in ECC
Next Topic:Publish FB Inhibited
Current Time: Wed Jul 30 23:08:51 EDT 2025
Powered by FUDForum. Page generated in 0.25534 seconds
