Home » Newcomers » Newcomers » can't invoke workbench after macos Big Sur upgrade
can't invoke workbench after macos Big Sur upgrade [message #1838571] Mon, 01 March 2021 11:47 Go to next message
I just upgraded to macos Big Sur and can't bring up Eclipse. There seems to be a lot of similar issues posted online and I have been trying to work through the workarounds posted, but am getting nowhere so far.
There are a bunch of stack dumps in the log but the first is listed below.
I am wondering is there is an easy and/or reliable workaround for this.
at org.eclipse.swt.widgets.Control.internal_new_GC(Control.java:2178)
at org.eclipse.swt.graphics.GC.<init>(GC.java:174)
at org.eclipse.swt.graphics.GC.<init>(GC.java:135)
at org.eclipse.ui.forms.widgets.Hyperlink.computeTextSize(Hyperlink.java:308)
at org.eclipse.ui.forms.widgets.ImageHyperlink.drawText(ImageHyperlink.java:128)
at org.eclipse.ui.forms.widgets.ImageHyperlink.paintHyperlink(ImageHyperlink.java:115)
at org.eclipse.ui.forms.widgets.ImageHyperlink.paintHyperlink(ImageHyperlink.java:85)
at org.eclipse.ui.forms.widgets.AbstractHyperlink.paint(AbstractHyperlink.java:276)
at org.eclipse.ui.forms.widgets.AbstractHyperlink.lambda$1(AbstractHyperlink.java:79)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:231)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4247)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1508)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1531)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1516)
at org.eclipse.swt.widgets.Control.drawWidget(Control.java:1277)
at org.eclipse.swt.widgets.Canvas.drawWidget(Canvas.java:172)
at org.eclipse.swt.widgets.Widget.drawRect(Widget.java:772)
at org.eclipse.swt.widgets.Canvas.drawRect(Canvas.java:166)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5884)
at org.eclipse.swt.internal.cocoa.OS.objc_msgSendSuper(Native Method)
at org.eclipse.swt.widgets.Display.applicationNextEventMatchingMask(Display.java:5138)
at org.eclipse.swt.widgets.Display.applicationProc(Display.java:5562)
at org.eclipse.swt.internal.cocoa.OS.objc_msgSend(Native Method)
at org.eclipse.swt.internal.cocoa.NSApplication.nextEventMatchingMask(NSApplication.java:94)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3707)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:818)
at org.eclipse.jface.window.Window.open(Window.java:794)
at org.eclipse.ui.internal.ide.application.IDEWorkbenchWindowAdvisor.promptOnExit(IDEWorkbenchWindowAdvisor.java:224)
at org.eclipse.ui.internal.ide.application.IDEWorkbenchAdvisor$1.handleEvent(IDEWorkbenchAdvisor.java:164)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4236)
at org.eclipse.swt.widgets.Display.close(Display.java:805)
at org.eclipse.ui.internal.handlers.QuitHandler.execute(QuitHandler.java:41)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:291)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:93)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:564)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:318)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:252)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:161)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:494)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:487)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:204)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:192)
at org.eclipse.e4.ui.workbench.renderers.swt.cocoa.CocoaUIHandler.runCommand(CocoaUIHandler.java:648)
at org.eclipse.e4.ui.workbench.renderers.swt.cocoa.CocoaUIHandler.access$5(CocoaUIHandler.java:634)
at org.eclipse.e4.ui.workbench.renderers.swt.cocoa.CocoaUIHandler$3.widgetSelected(CocoaUIHandler.java:506)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:249)
at org.eclipse.swt.widgets.Widget.sendSelectionEvent(Widget.java:1581)
at org.eclipse.swt.widgets.MenuItem.sendSelection(MenuItem.java:593)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5679)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1170)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1059)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:667)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:597)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:656)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:592)
at org.eclipse.equinox.launcher.Main.run(Main.java:1498)
Re: can't invoke workbench after macos Big Sur upgrade [message #1838572 is a reply to message #1838571] Mon, 01 March 2021 12:03 Go to previous messageGo to next message
Which release of Eclipse is it?
Re: can't invoke workbench after macos Big Sur upgrade [message #1838587 is a reply to message #1838572] Mon, 01 March 2021 22:06 Go to previous messageGo to next message
Thanks for the reply. I rev'd this afternoon and got past that issue. But now my plugins are stale so I am having other issues. I am having some trouble finding how to get the specific versions of of jface packages that I need for the new eclipse rev. From reading it seems that they come included with many eclipse installs. But there were no plugins at all included in my download.
Re: can't invoke workbench after macos Big Sur upgrade [message #1838591 is a reply to message #1838587] Tue, 02 March 2021 02:10 Go to previous message
It's not clear what you downloaded. The Committers package is the one most suitable for developing RCP applications that use JFace and SWT.
Previous Topic:how to add jar libraries to eclipse pydev ide?
Next Topic:Question about clang integration to Eclipse
Current Time: Mon Jul 21 05:51:34 EDT 2025
Powered by FUDForum. Page generated in 0.11951 seconds
