setting Maven settings.xml system wide? [message #1838123] |
Tue, 16 February 2021 17:30  |
The Maven plugin looks into user.home/.m2 for settings.xml.
This works when each user needs to have a separate setup, but what if we want to set up a master settings.xml that will be used as default for any user ?
I have read that maven first looks into its own configuration folder for a settings file.
Anyone knows where this folder is located? I found a few maven plugin folders in the Eclipse installation folder but no luck so far.
What I need is to define a system wide settings while letting individual users the ability to override by defining another settings file in their user. home
FUDForum. Page generated in 0.07248 seconds
