Home » Eclipse Projects » Trace Compass » JAXB Problem(Rebase to 6.1.0, respectively to Java 11 (from 8))
JAXB Problem [message #1838077] Mon, 15 February 2021 08:11 Go to next message
Hi all,
I am struggling with rebase of our plugin for TraceCompass (our trace type)
We are using a lot of XML analysis which are defined in external XML files. Until the version of Trace Compass 5.2.0 a Java 8, everything worked perfectly.
But the newer version are based on Java 11 (minimally) and there is the problem with JAXB libraries.
I am trying to import JAXB jars as external jar libraries, but still the XML files are not loaded because of missing com.sun.xml.bind.v2.ContextFactory. (I googled it a lot, but nothing worked).
So my question is, how do you read XML files for XML Analysis? I have to get rid of this JAXB dependency, but I do not know how to start or where to find code example inside of TC.
Thank you in advace for your answers.
Re: JAXB Problem [message #1838086 is a reply to message #1838077] Mon, 15 February 2021 12:08 Go to previous messageGo to next message
Hi Zdenek,
I empathize with your problems: the java 11 requirement had us also struggle with dependencies here and there on the incubator side.
About the XML, how do you add them for your trace type? There's a few plugins in Trace Compass that include XML files. I don't know if we had to do anything special when moving to Java 11. But maybe their configuration can inspire you. Look for example at the org.eclipse.tracecompass.lttng2.kernel.core plugin [1] (see the plugin.xml or the Manifest.mf), that is part of the feature org.eclipse.tracecompass.lttng2.kernel.
Also, if you look at the 2 commits from beginning of january on the Trace Compass Incubator [2], you may see what we had to do to be compatible with the java 11 requirement
[1] https://git.eclipse.org/c/tracecompass/org.eclipse.tracecompass.git/tree/lttng
[2] https://git.eclipse.org/c/tracecompass.incubator/org.eclipse.tracecompass.incubator.git/log/
I hope this helps,
Geneviève
Re: JAXB Problem [message #1838112 is a reply to message #1838086] Tue, 16 February 2021 05:06 Go to previous message
Hi Geneviève,
thank you for your quick answer! I looked on sources you sent me, to be precise, I look only at [1], because the incubator URL ends with 404.
BUT the first link helped me, because the org.eclipse.tracecompass.lttng2.kernel.core is using org.eclipse.tracecompass.tmf.analysis.xml.core and this is what I am looking for. It looks very similar to our solution. So hopefully I will be able to fix our solution based on this.
I will update my status when I will finish it.
Once again, thank you!
Previous Topic:kernel and ust traces alongside
Next Topic:Create a new trace type
Current Time: Tue Jul 22 03:33:32 EDT 2025
Powered by FUDForum. Page generated in 0.31725 seconds
