Home » Eclipse Projects » Subversive » Synchronize perspective does not show all outgoing changes after update
Synchronize perspective does not show all outgoing changes after update [message #18330] Tue, 06 May 2008 12:36 Go to next message
I use subversive for quite a few months now but recently (since ~1-2
months) I noticed that the synchronize view does not show me all outgoing
changes after I did an update via the synchronize perspective.
This does not happen all the time but I think it happens if I do an update
on the "project" item (the root item). Afterwards no outgoing changes in
this project are listed. After I continue developing in the source code,
sometimes the changes 'reappear'. The only reliable way to force a correct
display of outgoing changes for me is restarting Eclipse. Oddly enough the
files are marked as changed in other places, e.g. the package view.
The command line svn tool (1.4.2) does show all changes correctly all the
time.
Is there anybody out there which has similar experiences? I was not able
to find related bug reports or newsgroup postings although that may be due
to bad search phrases. I'm able to reproduce the problem on a second
computer with a fresh installation, though.
I use the latest Eclipse milestone build (Build id: I20080409-1425) on
CentOS Linux 5 (i386, latest updates) with Java 1.6.0_06-b02 (latest beta)
from Sun.
Suversive SVN Team Provider feature is 0.7.0.v20080425. Subversive SVN
Connector plug-in is 2.0.0.v20080214. Maybe the problem is related to the
Subversive SVN Kit connector (2.0.0.v20080423) but I need this one as
CentOS comes only with Subversion 1.4 and I definitely need the command
line client.
Any help is appreciated!
fs
Re: Synchronize perspective does not show all outgoing changes after update [message #18381 is a reply to message #18330] Wed, 07 May 2008 02:52 Go to previous messageGo to next message
Originally posted by: alexander.gurov.polarion.org
Dear Felix,
This is well known issue and we plan to see how it can be fixed. As
workaround you can try to switch between Synchronize View modes
(Incoming/Outgoing/Both) in that case view will be redrawed and lost items
should be shown again.
Re: Synchronize perspective does not show all outgoing changes after update [message #18408 is a reply to message #18381] Wed, 07 May 2008 03:22 Go to previous messageGo to next message
Thanks for your kind answer. :-)
Do you have a bug number so I can track the progress?
fs
Re: Synchronize perspective does not show all outgoing changes after update [message #19068 is a reply to message #18408] Wed, 07 May 2008 07:20 Go to previous messageGo to next message
Now we have this issue registered on our tracker. :)
You can check the state of this item at:
230853: Sometime resources are disappeared from Synchronize View
https://bugs.eclipse.org/bugs/show_bug.cgi?id=230853
Re: Synchronize perspective does not show all outgoing changes after update [message #1206659] Sun, 24 November 2013 01:33 Go to previous messageGo to next message
Re: Synchronize perspective does not show all outgoing changes after update [message #1206660] Sun, 24 November 2013 01:33 Go to previous messageGo to next message
Re: Synchronize perspective does not show all outgoing changes after update [message #1219295 is a reply to message #1206660] Tue, 03 December 2013 03:22 Go to previous message
There is another issue with the same appearance in Team component which is not fixed yet:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=266477
Previous Topic:Optimizing backup strategy with Tortoise SVN
Next Topic:ROOT Directory
Current Time: Thu Nov 06 15:34:44 EST 2025
Powered by FUDForum. Page generated in 0.03858 seconds
