Kura and Java 11 [message #1838069] |
Mon, 15 February 2021 05:45  |
Hi, I would like to know if there are any current future plans to move Eclipse Kura to Java 11?
Best regards Martin
Re: Kura and Java 11 [message #1839317 is a reply to message #1838070] |
Fri, 19 March 2021 05:04   |
Hi Metteo, thanks for your reply. I am currently trying to import the Kura Git repository (developer) into Eclipse as described in the Git. For this I took the Eclipse EE 2019.06 and selected OOmph in the import section and imported Kura there. But I can't start the emulator because some bundles are not found and some bundles have errors.
My workspace looks like this:
see attachement
The error message when I start the emulator looks like this:
!SESSION 2021-03-19 09:53:23.196 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_282
java.vendor=Private Build
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=de_DE
!ENTRY org.eclipse.osgi 2 0 2021-03-19 09:53:23.478
!MESSAGE The property 'osgi.configuration.area' with the value 'file:/home/biskup/Programming/EclipseKuraDevelop/EclipseHome/eclipse-workspace/.metadata/.plugins/org.eclipse.pde.core/Eclipse Kura Emulator/' is being overriden by the OSGi standard configuration property 'org.osgi.framework.storage' with the value '/tmp/osgi/framework_storage'.
!STACK 0
java.lang.IllegalArgumentException: The property 'osgi.configuration.area' with the value 'file:/home/biskup/Programming/EclipseKuraDevelop/EclipseHome/eclipse-workspace/.metadata/.plugins/org.eclipse.pde.core/Eclipse Kura Emulator/' is being overriden by the OSGi standard configuration property 'org.osgi.framework.storage' with the value '/tmp/osgi/framework_storage'.
at org.eclipse.osgi.internal.location.EquinoxLocations.<init>(EquinoxLocations.java:87)
at org.eclipse.osgi.internal.framework.EquinoxConfiguration.<init>(EquinoxConfiguration.java:548)
at org.eclipse.osgi.internal.framework.EquinoxContainer.<init>(EquinoxContainer.java:104)
at org.eclipse.osgi.launch.Equinox.<init>(Equinox.java:53)
at org.eclipse.osgi.launch.Equinox.<init>(Equinox.java:46)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:315)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:251)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
!ENTRY org.eclipse.kura.json.marshaller.unmarshaller.provider 4 0 2021-03-19 09:53:24.239
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.kura.json.marshaller.unmarshaller.provider [29]
Unresolved requirement: Import-Package: org.eclipse.kura.core.inventory.resources; version="[1.0.0,2.0.0)"
Unresolved requirement: Import-Package: org.eclipse.kura.core.configuration; version="[2.0.0,3.0.0)"
-> Export-Package: org.eclipse.kura.core.configuration; bundle-symbolic-name="org.eclipse.kura.core.configuration"; bundle-version="2.0.300.qualifier"; version="2.0.0"
org.eclipse.kura.core.configuration [14]
Unresolved requirement: Import-Package: org.eclipse.kura.core.util; version="[1.0.0,2.0.0)"
-> Export-Package: org.eclipse.kura.core.util; bundle-symbolic-name="org.eclipse.kura.core"; bundle-version="1.0.600.qualifier"; version="1.2.0"
org.eclipse.kura.core [19]
Unresolved requirement: Import-Package: org.h2; version="1.4.199"
at org.eclipse.osgi.container.Module.start(Module.java:463)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1845)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1838)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1781)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1743)
at org.eclipse.osgi.container.SystemModule.startWorker(SystemModule.java:269)
at org.eclipse.osgi.container.Module.doStart(Module.java:605)
at org.eclipse.osgi.container.Module.start(Module.java:468)
at org.eclipse.osgi.container.SystemModule.start(SystemModule.java:193)
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:439)
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:458)
at org.eclipse.osgi.launch.Equinox.start(Equinox.java:139)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:338)
!ENTRY org.eclipse.kura.xml.marshaller.unmarshaller.provider 4 0 2021-03-19 09:53:24.242
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.kura.xml.marshaller.unmarshaller.provider [42]
Unresolved requirement: Import-Package: org.eclipse.kura.core.configuration.metatype; version="[1.0.0,2.0.0)"
-> Export-Package: org.eclipse.kura.core.configuration.metatype; bundle-symbolic-name="org.eclipse.kura.core.configuration"; bundle-version="2.0.300.qualifier"; version="1.0.0"
!ENTRY org.eclipse.kura.asset.provider 4 0 2021-03-19 09:53:24.775
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.kura.asset.provider [4]
Unresolved requirement: Import-Package: org.eclipse.kura.core.configuration.util; version="[2.0.0,3.0.0)"
-> Export-Package: org.eclipse.kura.core.configuration.util; bundle-symbolic-name="org.eclipse.kura.core.configuration"; bundle-version="2.0.300.qualifier"; version="2.0.0"
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1665)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345)
!ENTRY org.eclipse.kura.camel.cloud.factory 4 0 2021-03-19 09:53:24.783
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.kura.camel.cloud.factory [8]
!ENTRY org.eclipse.kura.core.cloud 4 0 2021-03-19 09:53:24.791
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.kura.core.cloud [12]
Unresolved requirement: Import-Package: org.eclipse.kura.core.data
-> Export-Package: org.eclipse.kura.core.data; bundle-symbolic-name="org.eclipse.kura.core"; bundle-version="1.0.600.qualifier"; version="1.1.0"
!ENTRY org.eclipse.kura.core.configuration 4 0 2021-03-19 09:53:24.794
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.kura.core.configuration [14]
!ENTRY org.eclipse.kura.core.deployment 4 0 2021-03-19 09:53:24.796
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.kura.core.deployment [16]
!ENTRY org.eclipse.kura.core.net 4 0 2021-03-19 09:53:24.798
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.kura.core.net [17]
!ENTRY org.eclipse.kura.core 4 0 2021-03-19 09:53:24.800
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.kura.core [19]
!ENTRY org.eclipse.kura.emulator.net 4 0 2021-03-19 09:53:24.848
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.kura.emulator.net [24]
Unresolved requirement: Import-Package: org.eclipse.kura.core.net; version="[1.0.0,1.1.0)"
-> Export-Package: org.eclipse.kura.core.net; bundle-symbolic-name="org.eclipse.kura.core.net"; bundle-version="1.0.600.qualifier"; version="1.0.5"
!ENTRY org.eclipse.kura.web2 4 0 2021-03-19 09:53:24.858
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.kura.web2 [33]
Unresolved requirement: Import-Package: org.apache.felix.useradmin; version="1.0.0"
!ENTRY org.eclipse.kura.wire.component.provider 4 0 2021-03-19 09:53:24.867
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.kura.wire.component.provider [37]
Unresolved requirement: Import-Package: org.eclipse.kura.asset.provider; version="[2.0.0,2.1.0)"
-> Export-Package: org.eclipse.kura.asset.provider; bundle-symbolic-name="org.eclipse.kura.asset.provider"; bundle-version="2.0.300.qualifier"; version="2.0.0"
!ENTRY org.eclipse.kura.wire.provider 4 0 2021-03-19 09:53:24.874
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.kura.wire.provider [40]
Framework is running in emulation mode
2021-03-19T09:53:25,013 [Start Level: Equinox Container: e7ef00d4-a9d6-47eb-9535-394c288894b1] INFO o.a.c.i.o.Activator - Camel activator starting
2021-03-19T09:53:25,038 [Start Level: Equinox Container: e7ef00d4-a9d6-47eb-9535-394c288894b1] INFO o.a.c.i.o.Activator - Camel activator started
[Updated on: Fri, 19 March 2021 05:08] by Moderator
FUDForum. Page generated in 0.22729 seconds
