Home » Language IDEs » ServerTools (WTP) » where are codes generated by WTP tools
where are codes generated by WTP tools [message #182923] Sun, 19 November 2006 07:56 Go to next message
Originally posted by: qyyang79.yahoo.com
Hi all,
After using WTP tools (tried : Creating Top Down Web Service), I'd like to
know:
1) where are the code generated?
2) are they available for axis outside eclipse?
3) it appears that the codes generated are for axis 1.*; where the wtp
tools will be upgraded to work with axis2 1.1 (the latest)
Thanks and appreciated your answers.
Regards.
QY
Re: where are codes generated by WTP tools [message #183798 is a reply to message #182923] Wed, 06 December 2006 09:30 Go to previous messageGo to next message
QY,
1) with the help of the Axis emitters, the Web service wizard generates the
Java code for the service under the source folder of your Web project (by
default, "src"). The deploy.wsdd and undeploy.wsdd XML files are generated
under web-inf. The Axis servlet is inserted into web-inf/web.xml. Finally, the
jars that make up the Axis runtime are copied into web-inf/lib.
2) The resulting Web project can be exported as a WAR and run as-is on any Web
application server, such as Tomcat, outside of the scope of Eclipse.
3) WTP 1.5.2 includes Axis 1.3. We are working on a new set of plugins for
Axis2 in WTP 2.0 [1].
[1] http://wiki.eclipse.org/index.php/Axis2_Integration_in_WTP
Cheers - CB.
"Q. Yang" wrote:
> Hi all,
> know:
> Regards.
> QY
Re: where are codes generated by WTP tools [message #183855 is a reply to message #183798] Thu, 07 December 2006 02:16 Go to previous message
Hello Chris,
Looking at the WIKI link you attached, it says that "The target release for
the initial integration work is WTP 2.0", so I checked and found that "WTP
2.0 is based on Eclipse 4.0, which we assume will be released in 2Q2007"
( http://www.eclipse.org/webtools/development/planning/roadmap .html). Is this
true, because "Our target is to complete 3.3 in late June 2007"
( http://www.eclipse.org/eclipse/development/eclipse_project_p lan_3_3.html)?
"Chris Brealey" <cbrealey@ca.ibm.com> wrote in message
news:4576D3F0.32C25BFD@ca.ibm.com...
> QY,
> the
> the
> Web
> Cheers - CB.
> "Q. Yang" wrote:
>> Hi all,
>> to
>> know:
>> Regards.
>> QY
Previous Topic:Can't get Tomcat started correctly
Next Topic:Add a ejb JAR in my EAR project
Current Time: Wed Jul 23 05:20:27 EDT 2025
Powered by FUDForum. Page generated in 0.04157 seconds
