Home » Newcomers » Newcomers » "The catalog could not be loaded..." when installing Eclipse
"The catalog could not be loaded..." when installing Eclipse [message #1768208] Fri, 14 July 2017 12:59 Go to next message
When installing the eclipse installer, it can't connect to Internet and ask me to configure network proxy. What's the problem?
I searched for this issue and it appears it occurred 1 year ago. But no solution yet.
Re: "The catalog could not be loaded..." when installing Eclipse [message #1768209 is a reply to message #1768208] Fri, 14 July 2017 13:12 Go to previous messageGo to next message
I don't have a solution, just wanted to chime in that I am having the same issue. I had been using the eclipse installer 1.7.0 build 3057 (I think that was the build number) for the last two weeks or so. I installed the update earlier this morning when prompted (to build 3098) and I am now getting this error. I have tried the solutions in the threads from a year or so ago to no avail unfortunately.
Edit: It looks like its a server availability issue so we just have to wait until it gets resolved.
[Updated on: Fri, 14 July 2017 13:34] by Moderator
Re: "The catalog could not be loaded..." when installing Eclipse [message #1768210 is a reply to message #1768208] Fri, 14 July 2017 13:12 Go to previous messageGo to next message
*Deleted double post*
[Updated on: Fri, 14 July 2017 13:13] by Moderator
Re: "The catalog could not be loaded..." when installing Eclipse [message #1768213 is a reply to message #1768210] Fri, 14 July 2017 13:52 Go to previous messageGo to next message
It could just be the server is having a problem. The installer is trying to access http://www.eclipse.org/setups/setups.zip so if the server is having a problem serving that (and you've never downloaded it before, in which case an older cached version would be used), you'd get a dialog about the network failure. It works for me right now...
If you're behind a proxy, you'll need to configure the proxy/network settings needed for the installer to access that URL. Note that the latest installer (for Oxygen) is version 1.8...
Re: "The catalog could not be loaded..." when installing Eclipse [message #1837908 is a reply to message #1768213] Wed, 10 February 2021 04:10 Go to previous messageGo to next message
any idea what needed to be changed/updated in the proxy
Re: "The catalog could not be loaded..." when installing Eclipse [message #1837953 is a reply to message #1837908] Thu, 11 February 2021 04:49 Go to previous message
No, each proxy is different so there isn't just one way to configure it. Are you actually behind a proxy? Sometimes just the system firewall can block access too. In the worst case, download a package:
Previous Topic:Running Eclipse with JDK15 fails with exit code 1
Next Topic:generating Makefile
Current Time: Sun Nov 09 19:08:10 EST 2025
Powered by FUDForum. Page generated in 0.09236 seconds
