EMF - adding new model objects programmatically [message #1837938] |
Thu, 11 February 2021 01:24  |
Hello together,
I have a simple test code called example.tdlan2 written in Test Description Language (TDL) generated by Xtext.
Package Example {
Type STRING ;
Gate Type HTTP accepts STRING ;
Component Type EndPoint having {
gate http of type HTTP ;
Test Configuration BasicClientServer {
create SUT server of type EndPoint ;
create Tester client of type EndPoint ;
connect server.http to client.http ;
Test Description TD1 uses configuration BasicClientServer {
client.http sends "GET /store" to server.http ;
server.http sends "200 OK" to client.http ;
which can be transferred to an XMI representation:
<tdl:Package xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:tdl="http://www.etsi.org/spec/TDL/1.4.1" name="Example">
<packagedElement xsi:type="tdl:SimpleDataType" name="STRING"/>
<packagedElement xsi:type="tdl:GateType" name="HTTP" dataType="//@packagedElement.0"/>
<packagedElement xsi:type="tdl:ComponentType" name="EndPoint">
<gateInstance name="http" type="//@packagedElement.1"/>
</packagedElement>
<packagedElement xsi:type="tdl:TestConfiguration" name="BasicClientServer">
<componentInstance name="server" type="//@packagedElement.2"/>
<componentInstance name="client" type="//@packagedElement.2" role="Tester"/>
<connection>
<endPoint component="//@packagedElement.3/@componentInstance.0" gate="//@packagedElement.2/@gateInstance.0"/>
<endPoint component="//@packagedElement.3/@componentInstance.1" gate="//@packagedElement.2/@gateInstance.0"/>
</connection>
</packagedElement>
<packagedElement xsi:type="tdl:TestDescription" name="TD1" testConfiguration="//@packagedElement.3">
<behaviourDescription>
<behaviour xsi:type="tdl:CompoundBehaviour">
<block>
<behaviour xsi:type="tdl:Message" sourceGate="//@packagedElement.3/@connection.0/@endPoint.1">
<target targetGate="//@packagedElement.3/@connection.0/@endPoint.0"/>
<argument xsi:type="tdl:LiteralValueUse" value=""GET /store""/>
</behaviour>
<behaviour xsi:type="tdl:Message" sourceGate="//@packagedElement.3/@connection.0/@endPoint.0">
<target targetGate="//@packagedElement.3/@connection.0/@endPoint.1"/>
<argument xsi:type="tdl:LiteralValueUse" value=""200 OK""/>
</behaviour>
</block>
</behaviour>
</behaviourDescription>
</packagedElement>
</packagedElement>
</tdl:Package>
The model was loaded into an EMF resource (org.eclipse.emf.ecore.resource) as List <EObjects>:
public static void main(String [] args) {
//+1 added package initialisation as indicated in the wiki for predefined models
tdlPackage.eINSTANCE.eClass();
//+2 added OCL initialisation as it is used in the TDL implementation
EssentialOCLStandaloneSetup.doSetup();
//adapted for the specific Xtext-based language implementation
Injector injector = new TDLan2StandaloneSetup().createInjectorAndDoEMFRegistration();
XtextResourceSet resourceSet = injector.getInstance(XtextResourceSet.class);
//adapted for the filename declared above (relative to working directory)
Resource resource = resourceSet.getResource(URI.createURI("model/example.tdlan2"), true);
//adapted to our root / top-level element type - Package (TDL Package, not Java Package!)
Package p = (Package) resource.getContents().get(0);
Now I want to add another TestDescription containting a BehaviourDesription which also serves as a container for more Elements. There is also a missing nesting of a CompoundBehaviour (type Behaviour) and a Block.
//get the TestConfiguration from the EObject List
TestConfiguration TC = tdlFactory.eINSTANCE.createTestConfiguration();
for(PackageableElement pe : p.getPackagedElement()) {
if(pe instanceof TestConfiguration)
TC = (TestConfiguration) pe;
//get EndPoints defined in the TestConfiguration
GateReference gateSource = tdlFactory.eINSTANCE.createGateReference();
GateReference gateTarget = tdlFactory.eINSTANCE.createGateReference();
gateSource = TC.getConnection().get(0).getEndPoint().get(1);
gateTarget = TC.getConnection().get(0).getEndPoint().get(0);
Target t = tdlFactory.eINSTANCE.createTarget();
t.setTargetGate(gateTarget);
//Create an Interaction (Behaviour) and set EndPoints
Interaction iAction = tdlFactory.eINSTANCE.createInteraction();
iAction.setSourceGate(gateSource);
iAction.getTarget().add(t);
//Somewhere here should be CompoundBevahiour containing a block that contains the Action ??
CompoundBehaviour cb = tdlFactory.eINSTANCE.createCompoundBehaviour();
Block block = tdlFactory.eINSTANCE.createBlock();
cb.setBlock(block);
//Create BehaviourDescription and set Behaviour
BehaviourDescription bd = tdlFactory.eINSTANCE.createBehaviourDescription();
bd1.setBehaviour(iAction);
//Create a new TestDescription based on the TestConfiguration of the "TD1"
TestDescription td2 = tdlFactory.eINSTANCE.createTestDescription();
td3.setName("TD2");
td3.setTestConfiguration(TC);
td3.setBehaviourDescription(bd);
Finally, I try to save the changes into the input file (example.tdlan2) by calling the "resource" reference saved in "Package p", adding it to the List and saving into "example.tdlan2" again
//adding the new TestDescription to the List
p.getPackagedElement().add(td2);
//finally time to save the resource - no further modification possible
try {
resource.save(Collections.emptyMap());
} catch (IOException e) {
e.printStackTrace();
the result is getting a red wall of errors leading to the line:
and clearing the input file completely
Errors:
Exception in thread "main" java.lang.IllegalStateException
at org.eclipse.xtext.serializer.sequencer.AbstractSyntacticSequencer.enterAssignedParserRuleCall(AbstractSyntacticSequencer.java:354)
at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.acceptEObjectRuleCall(SequenceFeeder.java:325)
at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.acceptRuleCall(SequenceFeeder.java:354)
at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.accept(SequenceFeeder.java:248)
at org.eclipse.xtext.serializer.sequencer.BacktrackingSemanticSequencer.accept(BacktrackingSemanticSequencer.java:452)
at org.eclipse.xtext.serializer.sequencer.BacktrackingSemanticSequencer.createSequence(BacktrackingSemanticSequencer.java:512)
at org.etsi.mts.tdl.serializer.TDLan2SemanticSequencer.sequence_BehaviourDescription(TDLan2SemanticSequencer.java:592)
at org.etsi.mts.tdl.serializer.TDLan2SemanticSequencer.sequence(TDLan2SemanticSequencer.java:140)
at org.eclipse.xtext.serializer.sequencer.AbstractSemanticSequencer.createSequence(AbstractSemanticSequencer.java:68)
at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.acceptEObjectRuleCall(SequenceFeeder.java:327)
at org.etsi.mts.tdl.serializer.TDLan2SemanticSequencer.sequence_TestDescription(TDLan2SemanticSequencer.java:1797)
at org.etsi.mts.tdl.serializer.TDLan2SemanticSequencer.sequence(TDLan2SemanticSequencer.java:351)
at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.accept(SequenceFeeder.java:265)
at org.eclipse.xtext.serializer.sequencer.BacktrackingSemanticSequencer.accept(BacktrackingSemanticSequencer.java:445)
at org.etsi.mts.tdl.serializer.TDLan2SemanticSequencer.sequence_Package(TDLan2SemanticSequencer.java:1303)
at org.etsi.mts.tdl.serializer.TDLan2SemanticSequencer.sequence(TDLan2SemanticSequencer.java:262)
at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:122)
at org.eclipse.xtext.serializer.impl.Serializer.serializeToRegions(Serializer.java:144)
at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:150)
at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:202)
at org.eclipse.xtext.resource.XtextResource.doSave(XtextResource.java:387)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:1475)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:1044)
at org.etsi.example.load.run.exe.main(exe.java:210)
Any advise is appreciated.
FUDForum. Page generated in 0.09246 seconds
