Home » Eclipse Projects » Rich Client Platform (RCP) » SWT_AWT.new_Frame never returns on Linux
SWT_AWT.new_Frame never returns on Linux [message #1837880] Tue, 09 February 2021 08:15
I'm providing a plugin which is working fine since many years.
Yet i face an issue on Linux since the version 2020-09 (if i'm correct the first version installed with its own JRE).
In the code below the call to 'SWT_AWT.new_Frame' never returns but does not fire any error (the 'After' debug print won't be displayed).
Do you have any idea?
NOTE:
  • issue occurs with default JRE on Linux (version 14 in Eclipse 2020-09)
  • but same code is working if i update the eclipse.ini file to point to a JRE 11
  • and same code is also working on Windows with the default JRE version 14...
Code extract:
public class MyView extends ViewPart
public void createPartControl(final Composite parent)
Composite viewComposite = new Composite(parent, parent.getStyle() | SWT.EMBEDDED);
System.out.println("########## Before");
frame = SWT_AWT.new_Frame(viewComposite);
System.out.println("########## After");
Previous Topic:Deploy Eclipse RCP based IDE to cloud
Next Topic:Display progress bar when opening an editor takes a long time
Current Time: Mon Jul 21 09:20:05 EDT 2025
Powered by FUDForum. Page generated in 0.02818 seconds
