GDB hw debugging not uploading to target. [message #1837637] |
Wed, 03 February 2021 09:02  |
For a long time I have been using eclipse 2018 with gdb hw debugging.
While sometimes tricky to set up it was possible with some tinkering.
With the latest eclipse versions I am unable to have eclipse load the binary to my target board.
I am programming an STM32F429-Discovery board using the arm-none-eabi- toolchain, and openocd.
Connecting with arm-none-eabi-gdb to openocd manually works and these steps in gdb will get me started :
* target remote localhost:3333
* mon reset init
* file target-elf-file
* load
When debugging using elicpse it connects to the board and I can step through the last program loaded - it basically behaves as I would expect if I had deselected "load image" in the setup.
How can I debug this? Is there any way to see the step eclipse are taking when starting to debug?
FUDForum. Page generated in 0.10370 seconds
