Home » Modeling » TMF (Xtext) » Using FQN rule in reference rules does not work as expexcted.(Qualified name does not resolve)
Using FQN rule in reference rules does not work as expexcted. [message #1837082] Thu, 21 January 2021 12:54 Go to next message
I have the following parts in my grammar:
DynamicText:
	name=ID ":=" feature=[ecore::EStructuralFeature|QN] ("with" function=ID)
terminal QN:
	ID ('.' ID)+
the generated editor depicts that "DynamicText" could not be resolved.
var xxx := DynamicText.feature
I exspected " DynamicText.feature" gets parsed together as QN and then be compared to the scope provided here.
What is wrong ?
Re: Using FQN rule in reference rules does not work as expexcted. [message #1837083 is a reply to message #1837082] Thu, 21 January 2021 13:42 Go to previous messageGo to next message
afaik estructural features are not in the index so it wont work with default scoping.
maybe you can try an eclass with QN + a separate reference for the feature.
or you do a reference to an epackage and do scoping for the qualified features manually.
also see open model element dialog
Re: Using FQN rule in reference rules does not work as expexcted. [message #1837089 is a reply to message #1837083] Thu, 21 January 2021 17:19 Go to previous messageGo to next message
Sorry, I didn't mentioned I have a custom ScopeProvider for this feature and that delivers exactly what you see "DynamicText.feature"
That is why I am wondering about this behavior
Re: Using FQN rule in reference rules does not work as expexcted. [message #1837096 is a reply to message #1837089] Thu, 21 January 2021 23:48 Go to previous messageGo to next message
Then please give more details
Re: Using FQN rule in reference rules does not work as expexcted. [message #1837151 is a reply to message #1837096] Fri, 22 January 2021 15:06 Go to previous messageGo to next message
Christian Dietrich wrote on Thu, 21 January 2021 23:48
First Thanks for the answer.
Would you be so kind to specify which details you need to analyse the problem?
Re: Using FQN rule in reference rules does not work as expexcted. [message #1837156 is a reply to message #1837151] Fri, 22 January 2021 16:23 Go to previous messageGo to next message
The problem has disappeared some how.
Thank you for taking time for me.
Re: Using FQN rule in reference rules does not work as expexcted. [message #1837163 is a reply to message #1837156] Sat, 23 January 2021 00:44 Go to previous message
I would have expected: this is how my scope provider looks like
(Code snippet oder pseudo code here)
Previous Topic:Import of Xtext Grammar Model
Next Topic:[Formatter2] append newLine + spaces
Current Time: Sun Jul 20 23:45:48 EDT 2025
Powered by FUDForum. Page generated in 0.05014 seconds
