Home » Language IDEs » ServerTools (WTP) » Can't get Tomcat started correctly
Can't get Tomcat started correctly [message #183709] Tue, 05 December 2006 13:22 Go to next message
For some time I have been using Eclipse and WebTools to create a number
of Tapestry applications. Up to about a month ago I could run these
applications on Tomcat 5.0 server managed by eclipse. CATALINA_HOME
was set to /opt/jakarta-tomcat-5.0.30 and CATALINA_BASE in
the .metadata area inside my Eclipse workspace
(in other words the
For the past month, I have been (not :-) ) making a change to one of the
applications, and thinking about an upgrade to Tomcat 5.5.
Today, I have just come back to try and run the revised application
under 5.5 - my other applications I haven't touched.
In order to prevent any permissions problems, I downloaded the binary
version (5.5.20) of Tomcat for Linux from the Apache web site and
installed it in /opt/apache-tomcat-5.5.20. I copied all the .jar files
I had in the old 5.0.30 configuration under the shared/lib directory
into the same in in 5.5, and the postgresql jdbc driver from the
common/lib directory across as well.
Now I try and get something running on either version of tomcat its
failing.
On 5.0 there is a log file which shows
that "org.apache.tapestry.RedirectFilter" class is not found on any of
the applications as they start up. Since that is the class that
effectively acts as the gateway to the application, nothing is running
Given that the tapestry jar is in shared/lib directory, and I can look
inside this and find the appropriate class I assume this is some form
of classpath problem.
On 5.5 - where I have only "added" my revised application (called
usermgr) to the configuration, I have no log file at all. When I look
in the webapps directory in the .metadata/......../tmp1 directory the
application MINUS its WEB-INF directory are there, but that isn't.
In this case - I can't see any particular reason why this this directory
inside WebContent, but all the others made it across.
Can any one give me ANY clues as to where I should look to solve this
Re: Can't get Tomcat started correctly [message #183715 is a reply to message #183709] Tue, 05 December 2006 13:47 Go to previous messageGo to next message
In Tomcat 5.0 and 5.5, "shared/lib" is relative to CATALINA_BASE, i.e.
the one under ".metadata/...". Based on your description, the
webapps shouldn't have worked with the jars in the installation's
"shared/lib". You can import the catalina.properties file into the
server's subfolder of the Servers project in your workspace and make
changes to the "shared.loader", if desired.
I don't know why the WEB-INF directory wouldn't be present.
Larry
> (in other words the
> failing.
Re: Can't get Tomcat started correctly [message #183722 is a reply to message #183715] Tue, 05 December 2006 14:31 Go to previous messageGo to next message
Actually now you mention it - I did manually copy a load of stuff into
there. I'll take a look at it
Where can you specify in a project that the WebContent folder is the one
to use for Web Content. I have been using "git" for version control,
and when I am on the module test branch I completely remove that folder
(and change other parameters related to how to access the database) so
I am wondering if something in my project settings are screwed.
Re: Can't get Tomcat started correctly [message #183734 is a reply to message #183722] Tue, 05 December 2006 16:16 Go to previous messageGo to next message
The web content becomes part of the project's module due to a line like:
<wb-resource deploy-path="/" source-path="/WebContent"/>
in the ".setttings/org.eclipse.wst.common.component" file (called
".component" in WTP 1.0.x). If this is missing, that would explain why
there was no WEB-INF.
Larry
Re: Can't get Tomcat started correctly [message #183825 is a reply to message #183734] Wed, 06 December 2006 10:53 Go to previous messageGo to next message
> like:
> why there was no WEB-INF.
Actually I am now suspicious of this for a different reason. See the
contents below
<project-modules id="moduleCoreId" project-version="1.5.0">
<wb-module deploy-name="usermgr">
<module-type module-type-id="jst.web">
<version>2.3</version>
</module-type>
<wb-resource deploy-path="/WEB-INF/classes" source-path="/UnitTests"/>
<property name="java-output-path" value="/bin/"/>
<property name="context-root" value="usermgr"/>
</wb-module>
</project-modules>
In particular this line
coupled with the fact that the "/UnitTests/" directory does not exist
any longer. (The unit tests are only specified in a different branch
within my git repository - so don't exist on the branch were I try and
deploy onto Tomcat. In fact the code to deploy should come from a
different place.
Could that be the problem?
How do this file get set up - and how is it altered?
Re: Can't get Tomcat started correctly [message #183833 is a reply to message #183825] Wed, 06 December 2006 11:49 Go to previous message
When you create a Dynamic Web Project, a Java source folder with a
default name of "src" is included in the project. This folder is set up
to have any classes it builds included in WEB-INF/classes when the
project is published to a server. This is the purpose of lines like the
one you cite. Any additional Java source folders you add to the project
are also set up in the same fashion. If a source folder doesn't
contains classes you want included in WEB-INF/classes, you should
manually delete the corresponding entry from the "component" file. I
assume that would be the case for your "UnitTests" folder, even if it
existed. You can try removing the entry with the "UnitTests"
source-path and see if the situation improves. At the moment, I'm not
sure how WTP reacts when the "component" file references folders that
don't exist.
Larry
>> like:
> contents below
> </module-type>
> </wb-module>
> </project-modules>
> different place.
Previous Topic:Non nillable element
Next Topic:where are codes generated by WTP tools
Current Time: Fri Jul 25 20:31:29 EDT 2025
Powered by FUDForum. Page generated in 0.07137 seconds
