Home » Modeling » Graphiti » Problem with SVG(SVG error)
Problem with SVG [message #1837035] Thu, 21 January 2021 04:33 Go to next message
Hi all,
I use batik and canvas class to load and display an svg image .
Here my java code and please find attached the xml code of my svg image
mainFrame = new JFrame("Task Graph");
mainFrame.setSize(800,600);
mainFrame.setDefaultCloseOperation(JFrame.DISPOSE_ON_CLOSE);
mainFrame.setVisible(true);
Container pane = mainFrame.getContentPane();
pane.setLayout(new BorderLayout());
JSVGCanvas canvas = new JSVGCanvas();
canvas.setURI("output.xml");
pane.add(canvas, BorderLayout.CENTER);
pane.setVisible(true);
My problem is when I run the code:, I get this error:
"svg error: content is not allowed in prolog.
Could you help me please!!
Thank you in advance
  • Attachment: output.xml
    (Size: 4.81KB, Downloaded 126 times)
Re: Problem with SVG [message #1837116 is a reply to message #1837035] Fri, 22 January 2021 06:22 Go to previous messageGo to next message
Hi Mariem,
I'm not a SVG expert, but it seems that your xml file is somehow incorrect. From the error I think it might be the tags 'width="1967pt" height="76pt"
viewBox="0.00 0.00 1967.04 76.00"' within the svg tag, not sure if that is allowed.
Maybe you should reach out in a Batik or SVG specific group, this forum is mainly about Graphiti, we just use it as one export possibility.
Michael
Re: Problem with SVG [message #1837117 is a reply to message #1837116] Fri, 22 January 2021 06:48 Go to previous message
HI Michael,
Thank you for your response.
OK I will try with the other specific groups.
Mariem
[Updated on: Fri, 22 January 2021 06:49] by Moderator
Previous Topic:Detecting boundaries of the target container
Next Topic:delete
Current Time: Mon Jul 21 02:46:13 EDT 2025
Powered by FUDForum. Page generated in 0.03641 seconds
