Home » Eclipse Projects » Kura » How to publish MQTT messages with a Kura component?
How to publish MQTT messages with a Kura component? [message #1836949] Tue, 19 January 2021 12:04 Go to next message
this seems to be a very simple question, but I'm stuck with that for a longer time. Also just googling "kura publish MQTT" brings no satisfying results.
I want to publish MQTT messages with an individual JSON format on an individual topic.
In docu is the heater demo bundle as an example publishing application. It uses CloudService / CloudPublisher for publishing the messages.
It can only publish on the topic: <account-name>/<client-id>/heater/data and it can only publish KuraPayload with metrics which are always in the format:
  "metrics": {
    "String name" : "Object Value",
Is there a way to change topic and metrics using CloudService? Or is CloudService only for communication with a remote Kura server and I must use DataService? But then I'm wondering why there is not a single example using DataService.
Max
Re: How to publish MQTT messages with a Kura component? [message #1836989 is a reply to message #1836949] Wed, 20 January 2021 10:41 Go to previous messageGo to next message
the best option would be to create your version of the cloud connector. So that you can change your format for the message.
If you want to use the default connector, you can try to use the data service API and provide directly the formatted message as a byte[]. But you will lose all the advantages provided by the publish API, support for Wires, etc.
Matteo
Re: How to publish MQTT messages with a Kura component? [message #1837997 is a reply to message #1836989] Fri, 12 February 2021 06:47 Go to previous message
If somebody found this thread and wants to use the DataService, there is a good example on how to publish MQTT messages via DataService:
https://stackoverflow.com/a/31761816/14940207
Thanks Matteo for your help
Previous Topic:dpp file generated empty
Next Topic:Publish high rate messages with DataService without H2DbService
Current Time: Sun Nov 02 16:38:55 EST 2025
Powered by FUDForum. Page generated in 0.08028 seconds
