Eclipse installation issues [message #1836788] |
Wed, 13 January 2021 22:54  |
So I haven't coded anything in a long time and decided to pick it back up.
However, I am running into trouble installing a working Eclipse environment, even just for a Hello World example from the tutorial.
My issue is that regardless of how I install Eclipse (from package, from installer ect.) and no matter whether I install the basic version or the modelling version, I always end up with C:\users\(user)\.swt\lib\win32\x86_64\ being completely empty.
I know I need the runtime of the 32-bit eclipse, but that's simply not available for download?
If it helps, the first error thrown is:
Exception in thread "main" java.lang.UnsatisfiedLinkError: Could not load SWT library. Reasons:
no swt-win32-4940r23 in java.library.path: C:\Users\joshu\.p2\pool\plugins\org.eclipse.justj.openjdk.hotspot.jre.full.win32.x86_64_15.0.1.v20201027-0507\jre\bin;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\system32;C:\WINDOWS;V:/Software/eclipse-java-2020-12-R-win32-x86_64/eclipse//plugins/org.eclipse.justj.openjdk.hotspot.jre.full.win32.x86_64_15.0.1.v20201027-0507/jre/bin/server;V:/Software/eclipse-java-2020-12-R-win32-x86_64/eclipse//plugins/org.eclipse.justj.openjdk.hotspot.jre.full.win32.x86_64_15.0.1.v20201027-0507/jre/bin;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files (x86)\QuickTime\QTSystem\;C:\Users\joshu\AppData\Local\Microsoft\WindowsApps;V:\Software\eclipse-java-2020-12-R-win32-x86_64\eclipse;;.
no swt-win32 in java.library.path: C:\Users\joshu\.p2\pool\plugins\org.eclipse.justj.openjdk.hotspot.jre.full.win32.x86_64_15.0.1.v20201027-0507\jre\bin;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\system32;C:\WINDOWS;V:/Software/eclipse-java-2020-12-R-win32-x86_64/eclipse//plugins/org.eclipse.justj.openjdk.hotspot.jre.full.win32.x86_64_15.0.1.v20201027-0507/jre/bin/server;V:/Software/eclipse-java-2020-12-R-win32-x86_64/eclipse//plugins/org.eclipse.justj.openjdk.hotspot.jre.full.win32.x86_64_15.0.1.v20201027-0507/jre/bin;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files (x86)\QuickTime\QTSystem\;C:\Users\joshu\AppData\Local\Microsoft\WindowsApps;V:\Software\eclipse-java-2020-12-R-win32-x86_64\eclipse;;.
Can't load library: C:\Users\joshu\.swt\lib\win32\x86_64\swt-win32-4940r23.dll
Can't load library: C:\Users\joshu\.swt\lib\win32\x86_64\swt-win32.dll
P.S.: if you're curious, due to space reasons I am using a workspace on a Drivepool V: which is my RAID5.
oh, and it's WIN 10 64 bit.
Re: Eclipse installation issues [message #1836890 is a reply to message #1836828] |
Sun, 17 January 2021 21:21  |
Ok, this shit just got weirder.... After making the default install workspace and doing the tutorial again on there, the code suddenly started to work on my normal workspace too... and I changed absolutely NOTHING!
FUDForum. Page generated in 0.14327 seconds
