Home » Eclipse Projects » Plugin Development Environment (PDE) » [Solved] PDE version out of sync with JDT? How is this resolved?
[Solved] PDE version out of sync with JDT? How is this resolved? [message #1836656] Mon, 11 January 2021 07:19 Go to next message
Eclipse is spamming this error message. My interpretation is that org.eclipse.pde is trying to call something in org.eclipse.jdt, but the versions are out of sync somehow? Does this sound correct? I don't seem to be able to update the PDE version from within Eclipse, and I was wondering how I might go about doing this, or getting compatible plugins? Thank you.
!ENTRY org.eclipse.core.jobs 4 2 2021-01-11 10:21:26.644
!MESSAGE An internal error occurred during: "Initializing plug-in models".
!STACK 0
java.lang.NoSuchMethodError: 'org.eclipse.jdt.internal.compiler.env.IModule org.eclipse.jdt.internal.core.builder.ClasspathJrt.getModule(java.lang.String)'
	at org.eclipse.pde.internal.core.TargetPlatformHelper.querySystemPackages(TargetPlatformHelper.java:429)
	at org.eclipse.pde.internal.core.TargetPlatformHelper.getPlatformProperties(TargetPlatformHelper.java:393)
	at org.eclipse.pde.internal.core.MinimalState.getProfilePlatformProperties(MinimalState.java:182)
	at org.eclipse.pde.internal.core.MinimalState.initializePlatformProperties(MinimalState.java:176)
	at org.eclipse.pde.internal.core.PDEState.<init>(PDEState.java:67)
	at org.eclipse.pde.internal.core.PluginModelManager.initializeTable(PluginModelManager.java:602)
	at org.eclipse.pde.internal.core.PluginModelManager.targetReloaded(PluginModelManager.java:522)
	at org.eclipse.pde.internal.core.RequiredPluginsInitializer.lambda$0(RequiredPluginsInitializer.java:33)
	at org.eclipse.core.runtime.jobs.Job$2.run(Job.java:185)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
[Updated on: Tue, 12 January 2021 07:37] by Moderator
Re: PDE version out of sync with JDT? How is this resolved? [message #1836698 is a reply to message #1836656] Tue, 12 January 2021 07:37 Go to previous message
This was resolved by installing 'Eclipse Plug-in Development Environment' from the http://download.eclipse.org/releases/2019-12 repository. This effectively downgraded the version being used so that it was compatible with the JDT version. Seems like I could alternatively have switched to a more recent version of Eclipse.
Previous Topic:Is it possible to redirect to browser URL on splash image click?
Next Topic:Apache batik
Current Time: Sun Jul 27 12:53:00 EDT 2025
Powered by FUDForum. Page generated in 0.03721 seconds
