Home » Archived » BIRT » Nobody has tries to use Birt with Scriptcase Php framework ?
Nobody has tries to use Birt with Scriptcase Php framework ? [message #1836665] Mon, 11 January 2021 10:48
I'm wondering if nobody has tried to use Birt with Scriptcase framework.
They have a kind of PDF report embedded on solution based on TCPDF libraries but it's a kind of nightmare .
I'm not a programmer but I developed some projects on Crm, Service, Erp areas and I always fight with classic reporting like orders, invoice, and similars.
Do you think it would be easy to use Birt as external report designer and then manage the reports run within Scriptcase solution.
They are stupid question but I don't want to learn a new solution and then have issues on implementing it.
If you explain me how to do it (using simple words) it would be nice.
Ref to : www.scriptcase.net
Previous Topic:Data Sets -> Generate SQL Views
Next Topic:[SOLVED] "Java heap space" OutOfMemory error in renderTask
Current Time: Tue Sep 16 04:30:17 EDT 2025
Powered by FUDForum. Page generated in 0.04811 seconds
