Home » Newcomers » Newcomers » Eclipse Crashes on Opening (was working fine last week)(On macOS 11.0.1, after renaming my user.)
Eclipse Crashes on Opening (was working fine last week) [message #1836350] Tue, 29 December 2020 15:19 Go to next message
Hello Forum People,
I downloaded Eclipse early in the covid lockdown to give myself something to do, and have been enjoying playing around with Java for a while (keep in mind that I know nothing about how computers actually work).
Yesterday, though, I went to open the application for the first time after renaming my user (bolded for emphasis), and it crashed immediately. I have no idea if it's an Apple issue or an Eclipse one.
(edit by moderator)
The full log is copied to a Google Doc: https://docs.google.com/document/d/1m3GrzII6B6AriA2QxxGF4IiP8gA7kgMxYGW1bEl9Tpo/edit?usp=sharing
Many thanks,
Matthew C
[Updated on: Wed, 30 December 2020 12:34] by Moderator
Re: Eclipse Crashes on Opening (was working fine last week) [message #1836386 is a reply to message #1836350] Thu, 31 December 2020 15:58 Go to previous messageGo to next message
Thank you moderator for including the link directly in the post!
Re: Eclipse Crashes on Opening (was working fine last week) [message #1836413 is a reply to message #1836350] Sat, 02 January 2021 20:42 Go to previous messageGo to next message
Try to open it as a super user/root. If it works, then could be only a permission issue. If it doesnt work - then must be something else.
Re: Eclipse Crashes on Opening (was working fine last week) [message #1836531 is a reply to message #1836413] Wed, 06 January 2021 20:14 Go to previous message
Hi Iulian, thank you for your suggestion.
I tried opening Eclipse through the terminal as sudo, and there was still an error, though I had to open the log file to see it. The log didn't open automatically like before.
I decided to redownload the application, as I wasn't working on anything important, so I deleted everything and am starting over. Not sure how to close this issue, or even if I'm supposed to.
Thanks again,
Matthew
[Updated on: Wed, 06 January 2021 20:16] by Moderator
Previous Topic:[SOLVED] Eclipse doesn't launch. Could not load SWT library.
Next Topic:Window Builder. HELP ME!
Current Time: Mon Jul 21 09:16:40 EDT 2025
Powered by FUDForum. Page generated in 0.10831 seconds
