Home » Newcomers » Newcomers » I don't know which "workspace" to choose (from make.bat to eclipse)
I don't know which "workspace" to choose (from make.bat to eclipse) [message #1836272] Sun, 27 December 2020 16:31 Go to next message
I found a java project that is working through a "make.bat" file with a command thing, and i would like to run it on ECLIPSE for java developers
the bat file says :
del *.class
cd calculPack
del *.class
cd ..
cd flashAutomInterpretor
del *.class
cd ..
del FlashAutom.jar
javac -target 1.8 -source 1.8 Main.java & :: i modified this one to fit my jdk version
jar cvmf MANIFEST.MF FlashAutom.jar *
java -jar FlashAutom.jar
Anyway i would like to open the project inside Eclipse and run it from there (the reason is there are things in eclipse that can create the uml diagram class from the project i think so i want to run it on eclipse)
I tried to use the workspace that leads to all the folders and files, yet eclipse would not reconize it.
I tried to choose a folder called .metadata, and same thing it did not work.
Here is a picture of what the folder looks like
https://i.postimg.cc/NGV0MhNb/screenshot-523.png
Is there any particular method to move from make.bat to an eclipse way to compile ?
Many thanks.
[Updated on: Sun, 27 December 2020 16:32] by Moderator
Re: I don't know which "workspace" to choose (from make.bat to eclipse) [message #1836277 is a reply to message #1836272] Sun, 27 December 2020 19:02 Go to previous message
I tried my best and got this in the end :
Exception in thread "main" java.lang.NullPointerException
	at java.desktop/javax.swing.ImageIcon.<init>(ImageIcon.java:217)
	at BunnyEclipse/main.Aide$Fond.<init>(Aide.java:64)
	at BunnyEclipse/main.Aide.<init>(Aide.java:21)
	at BunnyEclipse/main.Periph.<init>(Periph.java:41)
	at BunnyEclipse/main.Main.main(Main.java:8)
Previous Topic: Spring Tools 3 Add-On for Spring Tools 4 cannot be installed
Next Topic:Can I use Eclipse IDE on a Ubuntu server?
Current Time: Sat Jul 26 04:00:05 EDT 2025
Powered by FUDForum. Page generated in 0.08760 seconds
