Home » Language IDEs » C / C++ IDE (CDT) » Symbol std::filesystem could not be resolved(Problem recognizing the symbol mentioned, but code compiles and runs)
Symbol std::filesystem could not be resolved [message #1836223] Thu, 24 December 2020 12:11 Go to next message
Hi everyone,
I have a problem when trying to use the standard library filesystem namespace, introduced with C++17.
Eclipse doesn't seem to recognize the symbol (std::filesystem is highlighted and says "symbol could not be recognized"), but I believe I updated the compiler accordingly, because the program compiles and runs, and I am able to call functions from that namespace.
I found another issue with a similar problem (https://www.eclipse.org/forums/index.php/t/285005/), but the suggestions provided didn't help me. I went to Project Properties -> C/C++ General -> Paths and Symbols -> Includes, and in include directories I added a lot of them like this: C:\MinGW\lib\gcc\mingw32\9.2.0\include\c++.
In the directory aforementioned there is a file called filesystem! What am I doing wrong? The error is very annoying.
Thanks to anybody who's willing to help!
Re: Symbol std::filesystem could not be resolved [message #1836240 is a reply to message #1836223] Fri, 25 December 2020 13:48 Go to previous messageGo to next message
Note that the include for <filesystem> isn't flagged.
The indexer was able to locate it.
The line with the namespace IS being flagged and std::filesystem is underlined.
This is probably indicating that std::filesystem doesn't exist.
It's possible that the __cpluplus macro set by the compiler builtin reporting has the wrong c++ standard.
Check that __cpluplus is greater than or equal to 201703L.
The builtin results can be viewed in the consolidated discovery dialogs
Project --> Properties --> C/C++ General --> Preprocessor Include Paths, Macros etc. --> Entries tab
If it is lower than 201703L then you have to include --std=c++17 in the builtins command.
For Paths and Symbols entries to be passed to the indexer,
you need to have the Managed Build Settings Entries enabled in
You shouldn't have to set the builtin includes in Paths and Symbols.
EDIT: I was saying std::filespace instead of std::filesystem. Fixed it.
[Updated on: Sat, 26 December 2020 01:49] by Moderator
Re: Symbol std::filesystem could not be resolved [message #1836244 is a reply to message #1836240] Fri, 25 December 2020 19:21 Go to previous messageGo to next message
First of all,
thanks for your kind and quick response, it gave me nice insights on where to look if I end up with similar problems in the future.
I looked up at the Entries tab for the GCC Built-In Compiler Settings as you mentioned and you were right: i had the __cplusplus equal to 2014.
Therefore I went to:
Project --> Properties --> C/C++ General --> Preprocessor Include Paths, Macros etc. --> Providers --> GCC Built-In Compiler Settings
and here I typed ${COMMAND} ${FLAGS} -E -P -v -dD --std=c++17 "${INPUTS}" in the Command to get compiler specs.
This changed __cplusplus to 201703L as you expected, but unfortunately this fix didn't seem to solve the issue. I'm still able to run my code but the std::filesystem is not recognized.
Do you know if there's another fix that I could make to have this to work? Thank you already in advance!
Re: Symbol std::filesystem could not be resolved [message #1836249 is a reply to message #1836244] Sat, 26 December 2020 01:31 Go to previous messageGo to next message
You may need to rebuild the index (Project --> C/C++ Index --> Rebuild)
Other than that, no.
EDIT:
Actually, if rebuilding doesn't work,
you may need to track down the header to where the namespace is defined.
There may be another reason why it is being ignored.
I don't have MinGW, so I can't say for sure.
[Updated on: Sat, 26 December 2020 01:44] by Moderator
Re: Symbol std::filesystem could not be resolved [message #1836253 is a reply to message #1836249] Sat, 26 December 2020 10:06 Go to previous message
Eureka!
Rebuilding the Index after all the operations made yesterday fixed the issue, before I only tried closing and opening the project but that didn't work.
I would never have made it without your help, thanks a lot!
[Updated on: Sat, 26 December 2020 10:11] by Moderator
Previous Topic:Fix project properties to run it.
Next Topic:How to index external folder?
Current Time: Mon Sep 01 00:36:22 EDT 2025
Powered by FUDForum. Page generated in 0.07367 seconds
