Home » Newcomers » Newcomers » Inactive editor tabs shows the file name in light grey color which is hard to read
Inactive editor tabs shows the file name in light grey color which is hard to read [message #1836239] Fri, 25 December 2020 13:41 Go to next message
Inactive editor tabs shows the file name in light grey color which is hard to read.
The issue is displayed in the image below with red borders
HTTPS imagebin.ca/v/5lzDJ0lEN0kn
Where do I change the inactive text editor tab colors?
Re: Inactive editor tabs shows the file name in light grey color which is hard to read [message #1836258 is a reply to message #1836239] Sat, 26 December 2020 16:56 Go to previous messageGo to next message
Are you using some combination of a third party theme and an old release of Eclipse? Check the "Colors and Fonts" preference page's "View and Editor Folders" options.
Re: Inactive editor tabs shows the file name in light grey color which is hard to read [message #1836260 is a reply to message #1836258] Sat, 26 December 2020 21:35 Go to previous messageGo to next message
Nitin Dahyabhai wrote on Sat, 26 December 2020 21:56
I did use a third party color theme but I changed to Default theme which did not fix the issue
I then uninstalled the theme but still the issue is not resolved.
Further I deleted the eclipse installation directory and reinstalled the same.
My eclipse version is
Eclipse IDE for Enterprise Java Developers (includes Incubating components)
Version: 2020-12 (4.18.0)
Build id: 20201210-1552
[Updated on: Sat, 26 December 2020 21:56] by Moderator
Re: Inactive editor tabs shows the file name in light grey color which is hard to read [message #1836268 is a reply to message #1836260] Sun, 27 December 2020 12:33 Go to previous messageGo to next message
I believe those preferences are tied to the workspace.
Re: Inactive editor tabs shows the file name in light grey color which is hard to read [message #1836270 is a reply to message #1836268] Sun, 27 December 2020 13:53 Go to previous messageGo to next message
Nitin Dahyabhai wrote on Sun, 27 December 2020 17:33
I switched to a freshly created new workspace but the issue is still present.
deleted eclipse installation folder and reinstalled and then created a fresh new workspace but no luck.
[Updated on: Sun, 27 December 2020 18:26] by Moderator
Re: Inactive editor tabs shows the file name in light grey color which is hard to read [message #1836319 is a reply to message #1836270] Mon, 28 December 2020 19:33 Go to previous messageGo to next message
If you have two combo boxes on the Appearance preference page, as in the current release, what are both of their values?
Re: Inactive editor tabs shows the file name in light grey color which is hard to read [message #1836322 is a reply to message #1836319] Mon, 28 December 2020 21:15 Go to previous messageGo to next message
Nitin Dahyabhai wrote on Tue, 29 December 2020 00:33
Theme: Light
Color and font theme: Default (current)
Re: Inactive editor tabs shows the file name in light grey color which is hard to read [message #1836327 is a reply to message #1836322] Tue, 29 December 2020 01:06 Go to previous messageGo to next message
I'm out of ideas. Is there an updated screenshot? Much of the original looked like the Dark theme.
Re: Inactive editor tabs shows the file name in light grey color which is hard to read [message #1836355 is a reply to message #1836327] Tue, 29 December 2020 16:58 Go to previous message
Nitin Dahyabhai wrote on Tue, 29 December 2020 06:06
I changed the theme to "Dark" and Fonts to "Classic Theme" and the problem is solved.
Thanks for your time.
Previous Topic:Bug in Eclipse IDE for JavaScript and Web Developers?
Next Topic:Eclipse for Java EE
Current Time: Sat Jul 26 00:24:21 EDT 2025
Powered by FUDForum. Page generated in 0.11309 seconds
