Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » how can i get/set more values by one FB CLIENT_1 in OPC DA
how can i get/set more values by one FB CLIENT_1 in OPC DA [message #1835943] Wed, 16 December 2020 21:43 Go to next message
environment: forte: 1.8.4, 4diac ide: 1.11.2
I am following the doc "OPC DA": https://www.eclipse.org/4diac/en_help.php?helppage=html/communication/opc.html,
especially, "fbInputItems/fbOutputItems: items to be added, items should be separated with a comma"
so I use the FB CLIENT_1,
set the ID as: opc[127.0.0.1:opcserversim.Instance.1:2000:0.01:T1,T2,T3:Q1,Q2,Q3]
set the SD_1 as: REAL#11,REAL#22,REAL#33
But the result I observed in OPC simulation server is: the item T1 was set to 11, but the other two items T2 and T3 was set to 0, not 22 and 33. Have you ever tested this function?
Re: how can i get/set more values by one FB CLIENT_1 in OPC DA [message #1835953 is a reply to message #1835943] Thu, 17 December 2020 02:29 Go to previous messageGo to next message
You need one input per data value you want to send. So with an CLIENT_1 you will only send 1 value. This is exactly the behavior that you are observing. In order to send and receive 3 values you need a CLIENT_3 FB. You can easily get such an FB by copy pasting the CLIENT_1 to CLIENT_3 and add the additional SD inputs and RD outputs. Don't forget the withs. Then you can already use it in your application, no code generation is needed.
I know that that process is not perfect. We want to have dynamically adjustable interfaces in 4diac IDE. I hope to find time in one of the next release cycles to implement it.
Re: how can i get/set more values by one FB CLIENT_1 in OPC DA [message #1835967 is a reply to message #1835953] Thu, 17 December 2020 06:03 Go to previous messageGo to next message
Thanks for your reply.
in 4diac ide 1.11.2 i can't find the way to add the additional SD inputs and RD outputs.
Thanks.
Re: how can i get/set more values by one FB CLIENT_1 in OPC DA [message #1835968 is a reply to message #1835967] Thu, 17 December 2020 06:07 Go to previous messageGo to next message
You need to do this in the type editor for your new CLIENT_3 FB type.
Re: how can i get/set more values by one FB CLIENT_1 in OPC DA [message #1836001 is a reply to message #1835968] Thu, 17 December 2020 22:32 Go to previous messageGo to next message
Your method is very effective. I can get any number of values now. thank you very much.
dachao xu
Re: how can i get/set more values by one FB CLIENT_1 in OPC DA [message #1836017 is a reply to message #1836001] Fri, 18 December 2020 05:05 Go to previous message
Happy to hear that!
Previous Topic:Bachmann M1 / VxWorks - Need advice how to begin
Next Topic:How to subscribe or publish with OPC DA?
Current Time: Mon Jul 21 08:18:02 EDT 2025
Powered by FUDForum. Page generated in 0.07232 seconds
