Home » Modeling » TMF (Xtext) » Problems with JDK 14
Problems with JDK 14 [message #1830185] Mon, 20 July 2020 04:22 Go to next message
I'm experimenting with Xtext, JDK 14 and Tycho (1.7.0).
When building with Tycho I get strange compilation errors like
appendable.append(";");
The method append(JvmType) in the type ITreeAppendable is not applicable for the arguments (String)
.collect(Collectors.joining(", ")));
The method joining(CharSequence) in the type Collectors is not applicable for the arguments (String)
I don't understand where the problem is, so I was wondering if that might be related to JDT used by Xtext?
I have no compilation problem in Eclipse...
thanks in advance
Lorenzo
Re: Problems with JDK 14 [message #1830196 is a reply to message #1830185] Mon, 20 July 2020 06:19 Go to previous messageGo to next message
Hi, which Xtext version do you use? Can you try with the latest milestone
Re: Problems with JDK 14 [message #1830202 is a reply to message #1830196] Mon, 20 July 2020 07:57 Go to previous messageGo to next message
I'm using Xtext 2.22.0.
I'll try with the latest milestone as well
Re: Problems with JDK 14 [message #1835804 is a reply to message #1830196] Sun, 13 December 2020 12:47 Go to previous messageGo to next message
I am currently experiencing a similar behavior. For the build I am using Tycho 2.1.0 and OpenJDK 15.0.1 but no Xtext.
The example:
		List<String> words = List.of("foo", "bar");
		CharSequence delimiter = ", ";
		String allWords = words.stream().collect(Collectors.joining(delimiter));
		System.out.println("result: " + allWords);
gives the following error:
[ERROR]         CharSequence delimiter = ", ";
[ERROR]                                  ^^^^
[ERROR] Type mismatch: cannot convert from String to CharSequence
Neither with Eclipse (2020-12) nor with plain javac there is this error. Therefore, I'd assume this to be an issue of Tycho or the JDT-compiler used by it.
Thanks in advance
Jakob
Re: Problems with JDK 14 [message #1835822 is a reply to message #1835804] Mon, 14 December 2020 06:27 Go to previous messageGo to next message
I think I have just cracked this bug. See https://bugs.eclipse.org/bugs/show_bug.cgi?id=569379
If you have a < 9 BREE you may need to specify
<deriveReleaseCompilerArgumentFromTargetLevel>false</deriveReleaseCompilerArgumentFromTargetLevel>
and if you have inconsistent org.eclipse.jdt.core.prefs the values passed to ECJ may be inconsistent. Woarkaround; make sure all your org.eclipse.jdt.core.prefs are the same; a good practice anyway.
Ed Willink
Re: Problems with JDK 14 [message #1835837 is a reply to message #1835822] Mon, 14 December 2020 11:24 Go to previous messageGo to next message
Hello Ed,
thank you very much for the hint with
this seems to fix this issue for the moment.
Nevertheless, I've created a small example project (attached zip) in which your solution is commented out. The execution environment is set to JavaSE-11.
The project can be built with OpenJDK 11 without any problems, but fails with later versions (tested it with OpenJDK 15.0.1).
Jakob
Re: Problems with JDK 14 [message #1835839 is a reply to message #1835837] Mon, 14 December 2020 13:22 Go to previous messageGo to next message
Please attach your repro to the existing / a new Bugzilla where the developers may see it.
Ed Willink
Re: Problems with JDK 14 [message #1835842 is a reply to message #1835839] Mon, 14 December 2020 14:13 Go to previous message
I just opened a new bug at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=569710
Jakob
Previous Topic:use generated classes in DSL file, problem of missing type
Next Topic:How to find the cross-references of an Eobject across files?
Current Time: Fri Jul 25 00:51:07 EDT 2025
Powered by FUDForum. Page generated in 0.13296 seconds
