Home » Newcomers » Newcomers » Hello world will not work, Failed to init ct.sym(First time trying Java, Please help)
Hello world will not work, Failed to init ct.sym [message #1835693] Thu, 10 December 2020 09:38 Go to next message
index.php/fa/39518/0/index.php/fa/39518/0/Hi,
I'm very very new to Java, and I am finding the whole experience hard to understand.
For starters, I was trying to run the hello world application on Eclipse. This is a fresh install of the latest Java 15, followed by the latest install of Eclipse 2020-09 (4.17.0).
As soon as I try to create the HelloWorld project following the built-in tutorial, I am confronted with the following error.
The project was not built due to "Failed to init ct.sym for C:\Users\Owner\AppData\Local\Temp\eoi6CE0.tmp\plugins\org.eclipse.justj.openjdk.hotspot.jre.minimal.stripped.win32.x86_64_14.0.2.v20200815-0932\jre\lib\jrt-fs.jar". Fix the problem, then try refreshing this project and building it since it may be inconsistent
This error message happens as soon as I create the project (Step 1). I haven't even entered in any code yet.
Re: Hello world will not work, Failed to init ct.sym [message #1835731 is a reply to message #1835693] Fri, 11 December 2020 00:10 Go to previous messageGo to next message
Is there a -vm option in your eclipse.ini? What does it point at?
What is in your Window -> Preferences -> Java -> Installed JVMs? Are you referencing your Java 15 installation there?
Re: Hello world will not work, Failed to init ct.sym [message #1835940 is a reply to message #1835731] Wed, 16 December 2020 16:56 Go to previous messageGo to next message
The following fixed the issue for me.
- Installed OpenJDK 15.0.1 on my computer.
- In Window/Preferences/Java/Installed JREs, I added a link to the new Java version (and named it "openjdk-15" to help identify it). I unchecked the existing jre and selected the newly installed.
- I started a NEW PROJECT, and for the JRE, made sure to select the new default jre.
- I copied over the source code of the failing project into the new project.
There may be a way to reconfigure a project that fails in this manner, rather than having to start anew. But putting the new openjdk-15 library on the module path with the "Build Path" configuration tool didn't help. It was only when I started a new project and made sure to specify the newly installed OpenJDK 15 that I was able to get my project to run.
I'm just another Eclipse User, and there is likely another way to fix this or a better explanation of what went wrong. But I thought it would be worth sharing the solution I found for anyone who also runs into this.
Re: Hello world will not work, Failed to init ct.sym [message #1835949 is a reply to message #1835940] Wed, 16 December 2020 23:54 Go to previous messageGo to next message
You can use Properties... from the context menu of a Java project and go to the Java Build Path. On the Libraries tab, you can use Edit... when selecting the JRE System Library entries. Here you have various ways of choosing/specifying the JRE. I.e., either by the mapping you have between your installed JREs and the Execution Environments (preferences nested under the Installed JREs preferences) or by choosing a very specific one.
Re: Hello world will not work, Failed to init ct.sym [message #1836316 is a reply to message #1835731] Mon, 28 December 2020 18:52 Go to previous messageGo to next message
Ed Merks wrote on Fri, 11 December 2020 05:10
Dear Ed Merks
I have Installed jdk 15.0.1
Then Installed Eclipse 2020 12
and facing same problem
and when I close the IDE and start it again it wont start and shows a white screen with JVM terminated Exit code = 2 and lots of other lines
  • Attachment: 1.png
    (Size: 49.23KB, Downloaded 376 times)
Re: Hello world will not work, Failed to init ct.sym [message #1836929 is a reply to message #1836316] Tue, 19 January 2021 00:05 Go to previous messageGo to next message
The workaround is the following: open the project properties by right-clicking on it in the package explorer. Go to the Java Compiler section and uncheck the Use '--release' option box. Select Yes to rebuild the project.
Re: Hello world will not work, Failed to init ct.sym [message #1837854 is a reply to message #1835693] Mon, 08 February 2021 11:32 Go to previous messageGo to next message
I am a complete noob, but this fixed problem for me:
window-preferences-java(dropdown)-installed JREs(dropdown)-execution environments
there i clicked on last execution environment (JavaSE-15)
then in Compatible JREs I put a check mark at jre
then apply and close
done :)
index.php/fa/39965/0/
  • Attachment: Untitled.png
    (Size: 71.27KB, Downloaded 6799 times)
Re: Hello world will not work, Failed to init ct.sym [message #1838284 is a reply to message #1836316] Sat, 20 February 2021 08:12 Go to previous messageGo to next message
What about uninstalling and then reinstalling, it sounds stupid but it's effective.
Re: Hello world will not work, Failed to init ct.sym [message #1838606 is a reply to message #1836316] Tue, 02 March 2021 05:58 Go to previous messageGo to next message
Hi ,
Did you find the fix. I am facing the same trouble
Re: Hello world will not work, Failed to init ct.sym [message #1838631 is a reply to message #1838606] Tue, 02 March 2021 12:17 Go to previous message
I gave up on Java a long time ago.
Previous Topic:Active provider in parameters file
Next Topic:I need help with displaying messages.
Current Time: Mon Sep 22 19:26:35 EDT 2025
Powered by FUDForum. Page generated in 0.08258 seconds
