Home » Newcomers » Newcomers » Hello, My Eclipse isn't working properly(SWT design, Window builder, issues, projects not showing up)
Hello, My Eclipse isn't working properly [message #1835362] Tue, 01 December 2020 12:25 Go to next message
Hello all,
I just downloaded the Eclipse IDE for Java Developers recently 2020-09 ( I have used it in the past on my previous device.) I had it working correctly but I had wanted to make a text-based game that had a pop-out application. I was following a tutorial by RYIsnow and he had designed a title page only using code, here's what the code sort of looked like ( I had deleted it because I thought that there was an issue with my software)
(after imports and public class etc,)
public Game(){
window = new JFrame();
window.setSize(800,600);
window.setDefaultCloseOperation(JFrame.EXIT_etc);
window.getContentPane().setBackground(Color.black):
window.layout etc
window.visible true etc
con = window.getContent();
titleNamePanel = new JPanel(); ( just background)
titleNameLabel = new JLabel(); (just text)
startButtonPanel = new Panel(): (just background) ( in blue so that it would show up)
startButton = new JButton(); ( text and background)
(I did the same/similar steps as window for all with black background and white text. )
then I added titleNameLabel to its panel
and startButton to its panel
and those panels to containers.
when I ran it, it had just a black background. I changed the colors to be different from each other and it showed up but I had wanted it to look nicer so I tried to download window builder (help> download new software > general software > everything below SWT Designer.)
but this had not worked and I could not open the design tab. ( I have gotten this to work on my previous device but I couldn't remember what I had done to make it work.
It had made my projects show up as a gray screen (SWT Application window).
If someone knows the solution to this please let me know!
  • Attachment: Capture2.MHT
    (Size: 494.70KB, Downloaded 131 times)
  • Attachment: Capture3.MHT
    (Size: 108.13KB, Downloaded 157 times)
Re: Hello, My Eclipse isn't working properly [message #1835365 is a reply to message #1835362] Tue, 01 December 2020 14:05 Go to previous messageGo to next message
Whatever those attachments are supposed to convey, you might want to consider changing them out for simple images. From
what's written, I also can't tell what you're asking about--are you missing a Design tab, or is it there and showing up as gray? And
is that the actual source code you're editing that turns up gray?
Re: Hello, My Eclipse isn't working properly [message #1835978 is a reply to message #1835365] Thu, 17 December 2020 11:05 Go to previous message
Sorry about the attachments and the late reply, I'm missing a design tab so I was typing in the code and when I would run the code it would show up as gray. It only seemed to be the code that two jpanels had BLACK as the set color. I think it should both work even if they are the same color but I'm not sure.
Previous Topic:Eclipse for NIOS (Intel née Altera C Code Development) won't import/create new
Next Topic:Eclipse Jenkins build server connection
Current Time: Mon Jul 21 02:34:34 EDT 2025
Powered by FUDForum. Page generated in 0.10441 seconds
