Home » Archived » BIRT » Conditional formatting(Conditional formatting)
Conditional formatting [message #1835160] Thu, 26 November 2020 02:12 Go to next message
Hello All,
I am new to BIRT and currently looking to create a report/dashboard in BIRT 4.8 report designer.
I am trying to get conditional formatting working on a TIME field but having some difficulty.
Are there any examples or example reports I can see at all?
any help would be much appreciated.
Thanks in advance
Re: Conditional formatting [message #1835284 is a reply to message #1835160] Mon, 30 November 2020 01:47 Go to previous messageGo to next message
I would convert the data to strings and work with a string. you can get the data and process it with a script. or you can use a highlight list
What do you want to get? more details, please.
Re: Conditional formatting [message #1835300 is a reply to message #1835284] Mon, 30 November 2020 07:35 Go to previous messageGo to next message
I have attached the design, I have tried to use the highlights feature but that hasn't worked. If in the TIMEREC field the data is coming in as e.g. 12:34
What I am looking for if the Time is : -
less than 30 Mins to be orange
Greater than 60 Mins to be red
Thanks in advance
Re: Conditional formatting [message #1835313 is a reply to message #1835300] Mon, 30 November 2020 10:26 Go to previous messageGo to next message
hi, Asif. I created dataset1 with time in format like you do and used highlight list to change color of text
Re: Conditional formatting [message #1835341 is a reply to message #1835313] Tue, 01 December 2020 03:14 Go to previous messageGo to next message
Thank you for this. This works well with the time in the fields.
But what I would like is to compare the current time vs the time in field. I have tried to use the BirtDateTime.Now() but this is giving me a date and time together.
thanks in advance
Re: Conditional formatting [message #1835344 is a reply to message #1835341] Tue, 01 December 2020 04:18 Go to previous messageGo to next message
Hey. hope this helps. be careful, I change the background based on the current time. the report constantly checks the time every time a new date is created. if you need to use a date when the report is run, then create it once and put it in a variable
Re: Conditional formatting [message #1835345 is a reply to message #1835344] Tue, 01 December 2020 04:46 Go to previous messageGo to next message
Hey thanks for helping me with this, but i have put that script in and comes up with an error.
can you give me the example reportdesign.
Also you have said red back ground, but after 30 mins it should be orange?
Re: Conditional formatting [message #1835347 is a reply to message #1835345] Tue, 01 December 2020 05:14 Go to previous messageGo to next message
-------------Also you have said red back ground, but after 30 mins it should be orange?
no. It doesn't work this way. I make this red for example. You can change it. just replace red->orange.But you cant change colors /tables after rendering phase.
Re: Conditional formatting [message #1835354 is a reply to message #1835347] Tue, 01 December 2020 07:34 Go to previous messageGo to next message
I seem to get the error below : -
I am connecting to a mySQL database.
org.eclipse.birt.report.engine.api.EngineException: Invalid javascript expression: TypeError: Cannot find function split in object Tue Dec 01 2020 12:32:33 GMT-0000 (GMT). (#1)
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1252)
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1197)
at org.eclipse.birt.report.engine.executor.ReportItemExecutor.evaluate(ReportItemExecutor.java:288)
at org.eclipse.birt.report.engine.executor.TextItemExecutor.executeHtmlText(TextItemExecutor.java:115)
at org.eclipse.birt.report.engine.executor.TextItemExecutor.execute(TextItemExecutor.java:70)
at org.eclipse.birt.report.engine.executor.ReportExecutorUtil.executeAll(ReportExecutorUtil.java:87)
at org.eclipse.birt.report.engine.executor.ReportExecutorUtil.executeAll(ReportExecutorUtil.java:92)
at org.eclipse.birt.report.engine.executor.ReportExecutor.createPageExecutor(ReportExecutor.java:229)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportExecutor.createPageExecutor(WrappedReportExecutor.java:49)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplciateReportExecutor.createPageExecutor(SuppressDuplciateReportExecutor.java:61)
at org.eclipse.birt.report.engine.executor.ReportExecutorUtil.executeMasterPage(ReportExecutorUtil.java:63)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.start(HTMLPageLM.java:147)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:91)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.presentation.ReportDocumentBuilder.build(ReportDocumentBuilder.java:258)
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTask.java:273)
at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask.java:89)
at org.eclipse.birt.report.service.ReportEngineService.runReport(ReportEngineService.java:1325)
at org.eclipse.birt.report.service.BirtViewerReportService.runReport(BirtViewerReportService.java:159)
at org.eclipse.birt.report.service.actionhandler.BirtRunReportActionHandler.__execute(BirtRunReportActionHandler.java:81)
at org.eclipse.birt.report.service.actionhandler.BirtGetPageActionHandler.__checkDocumentExists(BirtGetPageActionHandler.java:58)
at org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.prepareParameters(AbstractGetPageActionHandler.java:118)
at org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.__execute(AbstractGetPageActionHandler.java:103)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143)
at org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleGetPage(BirtDocumentProcessor.java:87)
at sun.reflect.GeneratedMethodAccessor125.invoke(Unknown Source)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112)
at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
at sun.reflect.GeneratedMethodAccessor124.invoke(Unknown Source)
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:865)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1655)
at org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerFilter.java:68)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1634)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:533)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1253)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1155)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144)
at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:219)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:126)
at org.eclipse.jetty.server.Server.handle(Server.java:531)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:352)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:260)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:760)
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:678)
Caused by: org.eclipse.birt.core.exception.CoreException: Invalid javascript expression: TypeError: Cannot find function split in object Tue Dec 01 2020 12:32:33 GMT-0000 (GMT). (#1)
at org.eclipse.birt.report.engine.javascript.JavascriptEngine.evaluate(JavascriptEngine.java:300)
at org.eclipse.birt.core.script.ScriptContext.evaluate(ScriptContext.java:159)
at org.eclipse.birt.report.engine.executor.ExecutionContext.evaluate(ExecutionContext.java:791)
at org.eclipse.birt.report.engine.executor.ExecutionContext.evaluate(ExecutionContext.java:720)
at org.eclipse.birt.report.engine.executor.ReportItemExecutor.evaluate(ReportItemExecutor.java:284)
... 81 more
Caused by: org.mozilla.javascript.EcmaError: TypeError: Cannot find function split in object Tue Dec 01 2020 12:32:33 GMT-0000 (GMT). (#1)
at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRuntime.java:3687)
at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRuntime.java:3665)
at org.mozilla.javascript.ScriptRuntime.typeError(ScriptRuntime.java:3693)
at org.mozilla.javascript.ScriptRuntime.typeError2(ScriptRuntime.java:3712)
at org.mozilla.javascript.ScriptRuntime.notFunctionError(ScriptRuntime.java:3783)
at org.mozilla.javascript.ScriptRuntime.getPropFunctionAndThisHelper(ScriptRuntime.java:2269)
at org.mozilla.javascript.ScriptRuntime.getPropFunctionAndThis(ScriptRuntime.java:2251)
at org.mozilla.javascript.gen._inline__420._c_script_0(:1)
at org.mozilla.javascript.gen._inline__420.call()
at org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:394)
at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:3091)
at org.mozilla.javascript.gen._inline__420.exec()
at org.eclipse.birt.report.engine.javascript.JavascriptEngine.evaluate(JavascriptEngine.java:291)
... 85 more
org.eclipse.birt.report.engine.api.EngineException: Cannot execute the statement.
org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL statement does not return a ResultSet object.
SQL error #1:GC overhead limit exceeded
java.sql.SQLException: GC overhead limit exceeded
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1231)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:96)
at org.eclipse.birt.report.engine.executor.TableItemExecutor.execute(TableItemExecutor.java:62)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.emitter.ReportItemEmitterExecutor.execute(ReportItemEmitterExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
Caused by: org.eclipse.birt.data.engine.odaconsumer.OdaDataException: Cannot execute the statement.
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.newException(ExceptionHandler.java:52)
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.throwException(ExceptionHandler.java:108)
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.throwException(ExceptionHandler.java:84)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.execute(PreparedStatement.java:586)
at org.eclipse.birt.data.engine.executor.DataSourceQuery.execute(DataSourceQuery.java:980)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQueryExecutor.executeOdiQuery(PreparedOdaDSQuery.java:607)
at org.eclipse.birt.data.engine.impl.QueryExecutor.execute(QueryExecutor.java:1257)
at org.eclipse.birt.data.engine.impl.ServiceForQueryResults.executeQuery(ServiceForQueryResults.java:233)
at org.eclipse.birt.data.engine.impl.QueryResults.getResultIterator(QueryResults.java:178)
at org.eclipse.birt.report.engine.data.dte.QueryResultSet.(QueryResultSet.java:98)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteQuery(DteDataEngine.java:168)
at org.eclipse.birt.report.engine.data.dte.DataGenerationEngine.doExecuteQuery(DataGenerationEngine.java:83)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:286)
at org.eclipse.birt.report.engine.executor.ExecutionContext.executeQuery(ExecutionContext.java:1954)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:80)
... 77 more
Caused by: org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL statement does not return a ResultSet object.
at org.eclipse.birt.report.data.oda.jdbc.Statement.executeQuery(Statement.java:482)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.doExecuteQuery(OdaQuery.java:480)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.executeQuery(OdaQuery.java:444)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.execute(PreparedStatement.java:575)
... 88 more
Caused by: java.sql.SQLException: GC overhead limit exceeded
at com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:129)
at com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:97)
at com.mysql.cj.jdbc.exceptions.SQLExceptionsMapping.translateException(SQLExceptionsMapping.java:122)
at com.mysql.cj.jdbc.ClientPreparedStatement.executeInternal(ClientPreparedStatement.java:953)
at com.mysql.cj.jdbc.ClientPreparedStatement.executeQuery(ClientPreparedStatement.java:1003)
at org.eclipse.birt.report.data.oda.jdbc.Statement.executeQuery(Statement.java:478)
... 91 more
Re: Conditional formatting [message #1835356 is a reply to message #1835354] Tue, 01 December 2020 08:39 Go to previous message
do you get Object "DATE" from SQL?and it had type"datetime". you must convert it into strings. or getHours(newData()) in separately column.
you cant work with DATE like STRINGS
Previous Topic:BIRT - Hide extra header cells when using drop detail
Next Topic:birt presto jdbc connexion
Current Time: Sun Jul 20 23:49:39 EDT 2025
Powered by FUDForum. Page generated in 0.52069 seconds
