Home » Modeling » Papyrus » How can I modify <<ExternLibrary>> std?
How can I modify <<ExternLibrary>> std? [message #1835199] Thu, 26 November 2020 19:44 Go to next message
I was wondering if it is possible to modify the <<ExternLibrary>> std because I need to work with std::thread and it is not contained in it.
Re: How can I modify <<ExternLibrary>> std? [message #1835228 is a reply to message #1835199] Fri, 27 November 2020 07:52 Go to previous messageGo to next message
You can't. Libraries deployed in bundles in the Eclipse/Papyrus workbench are read-only resources.
But you can create your own library with the types you need, to share them amongst your design models. Only I don't know what would be the semantics of importing multiple distinct packages named 'std'. Probably for code generation it wouldn't matter.
HTH,
Christian
Re: How can I modify <<ExternLibrary>> std? [message #1835233 is a reply to message #1835228] Fri, 27 November 2020 09:12 Go to previous messageGo to next message
Christian Damus wrote on Fri, 27 November 2020 07:52
Well, that sucks. I was fearing I would have to do that.
Yeah, it's only for code generation. Do you know how can I create my own library? Is that process just as a regular project?
Re: How can I modify <<ExternLibrary>> std? [message #1835238 is a reply to message #1835233] Fri, 27 November 2020 10:02 Go to previous messageGo to next message
A model library is just a package that contains reusable constructs meant to be imported into/referenced by your models. So, yeah, the very same process.
You might choose to stereotype your library package as «ModelLibrary» for documentation purposes; maybe some tools would treat it specially, I don't know.
Christian
Re: How can I modify <<ExternLibrary>> std? [message #1835302 is a reply to message #1835238] Mon, 30 November 2020 07:46 Go to previous messageGo to next message
... or you create a bug for Papyrus SW designer with the lists of elements missing for you in the C++ std library. Of course, are lot are missing as the C++ library is huge. Thus, I don't aim for a complete library, but it would be good if the likelihood to find relevant classes inside becomes a bit bigger.
Re: How can I modify <<ExternLibrary>> std? [message #1835310 is a reply to message #1835302] Mon, 30 November 2020 09:36 Go to previous message
Ansgar Radermacher wrote on Mon, 30 November 2020 07:46
Well, I could do that, but that means I would be creating a lot of bugs and I don't think that you should use your time on adding stuff to std when you can use it for more valuable activities like fixing real issues.
I will just create my own std and add stuff as I need it. I just thought it was a way of modifying the included one myself, hence the question in the original post.
Previous Topic:Issues creating my own std library
Next Topic:Class attributes and methods missing when deleting it and dragging it again to the diagram.
Current Time: Thu Jul 24 23:37:48 EDT 2025
Powered by FUDForum. Page generated in 0.09912 seconds
