Re: How can I modify <<ExternLibrary>> std? [message #1835310 is a reply to message #1835302] |
Mon, 30 November 2020 09:36  |
Ansgar Radermacher wrote on Mon, 30 November 2020 07:46... or you create a bug for Papyrus SW designer with the lists of elements missing for you in the C++ std library. Of course, are lot are missing as the C++ library is huge. Thus, I don't aim for a complete library, but it would be good if the likelihood to find relevant classes inside becomes a bit bigger.
Well, I could do that, but that means I would be creating a lot of bugs and I don't think that you should use your time on adding stuff to std when you can use it for more valuable activities like fixing real issues.
I will just create my own std and add stuff as I need it. I just thought it was a way of modifying the included one myself, hence the question in the original post.
FUDForum. Page generated in 1.09065 seconds
