"Replace with HEAD revision" does not work during interactive rebase [message #1834526] |
Wed, 11 November 2020 13:33  |
Hi there,
if you start an interactive rebase and set a commit to EDIT, then edit some file and then try to reset that file to the HEAD version via the context menu entry "Replace with HEAD revision" in the Git staging view, nothing happens.
I've noticed the problem for a while, but only today took a look into the error view, which shows the Exception underneath.
My versions are: "Eclipse 2020-09" with "Eclipse EGit Git integration for Eclipse 5.9.0.202009080501-r org.eclipse.egit"
Best regards
Rice
org.eclipse.core.commands.NotHandledException: There is no handler to execute for command org.eclipse.egit.ui.team.ReplaceWithHead
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:501)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:487)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:213)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommandInContext(LegacyHandlerService.java:440)
at org.eclipse.egit.ui.internal.CommonUtils.runCommand(CommonUtils.java:218)
at org.eclipse.egit.ui.internal.CommonUtils.runCommand(CommonUtils.java:182)
at org.eclipse.egit.ui.internal.staging.StagingView$50.run(StagingView.java:3377)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:474)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:579)
at org.eclipse.jface.action.ActionContributionItem.lambda$4(ActionContributionItem.java:413)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4195)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1037)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4012)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3612)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:823)
at org.eclipse.jface.window.Window.open(Window.java:799)
at org.eclipse.ui.internal.views.log.EventDetailsDialog.open(EventDetailsDialog.java:191)
at org.eclipse.ui.internal.views.log.EventDetailsDialogAction.run(EventDetailsDialogAction.java:102)
at org.eclipse.ui.internal.views.log.LogView.lambda$2(LogView.java:591)
at org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredViewer.java:782)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:174)
at org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(StructuredViewer.java:779)
at org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSelect(AbstractTreeViewer.java:1531)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSelected(StructuredViewer.java:1213)
at org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEvent(OpenStrategy.java:251)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.java:249)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:308)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1157)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1046)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:644)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:551)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:153)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:150)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
FUDForum. Page generated in 0.09045 seconds
