Validation problems [message #1834877] |
Thu, 19 November 2020 10:00  |
I have an RCP built on Papyrus so that I can add tooling specific to our DSML. We have a specific Profile we use but the models we create are straight UML so can also be edited in vanilla Papyrus. I want to add some validation constraints to our RCP and so have created the requisite plugin but the validation threw an exception when run. I tried running validation in the Papyrus RCP against the same model and got the same result. I then tried creating a small model from scratch with our profile applied and the validation ran without errors.
Unsurprisingly, I conclude from that that we have somehow managed to corrupt our model such that it breaks validation. That leaves me with two questions:
1) Might it be possible in future to stop the validation from failing and instead identify where the issue is with the model?
2) Is there any hope of tracking down the nature of the issue with the model from the error in the log?
The log entry is below.
Oliver
!ENTRY org.eclipse.emf.edit.ui 2 0 2020-11-19 14:44:13.070
!MESSAGE
!STACK 0
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:397)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:469)
at org.eclipse.papyrus.infra.services.validation.commands.AbstractValidateCommand.runValidation(AbstractValidateCommand.java:169)
at org.eclipse.papyrus.infra.services.validation.commands.ValidateModelCommand.doExecuteWithResult(ValidateModelCommand.java:79)
at org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTransactionalCommand.doExecute(AbstractTransactionalCommand.java:248)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:150)
at org.eclipse.papyrus.infra.emf.gmf.command.GMFtoEMFCommandWrapper.execute(GMFtoEMFCommandWrapper.java:123)
at org.eclipse.papyrus.infra.services.validation.handler.AbstractCommandHandler.execute(AbstractCommandHandler.java:157)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:283)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:97)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:319)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:253)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:173)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:156)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:488)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:487)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:213)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:438)
at org.eclipse.e4.ui.workbench.renderers.swt.AbstractContributionItem.handleWidgetSelection(AbstractContributionItem.java:449)
at org.eclipse.e4.ui.workbench.renderers.swt.AbstractContributionItem.lambda$2(AbstractContributionItem.java:475)
at org.eclipse.e4.ui.workbench.renderers.swt.AbstractContributionItem$$Lambda$429/0000000000000000.handleEvent(Unknown Source)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4213)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1037)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4030)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3630)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1158)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1047)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:658)
at org.eclipse.ui.internal.Workbench$$Lambda$208/0000000000000000.run(Unknown Source)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:557)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:154)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:150)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
at org.eclipse.equinox.launcher.Main.run(Main.java:1447)
at org.eclipse.ocl.pivot.uml.internal.labels.SlotLabelGenerator.buildLabelFor(SlotLabelGenerator.java:29)
at org.eclipse.ocl.pivot.uml.internal.labels.SlotLabelGenerator.buildLabelFor(SlotLabelGenerator.java:1)
at org.eclipse.ocl.pivot.labels.LabelGeneratorRegistry.buildSubLabelFor(LabelGeneratorRegistry.java:216)
at org.eclipse.ocl.pivot.labels.LabelGeneratorRegistry.buildLabelFor(LabelGeneratorRegistry.java:197)
at org.eclipse.ocl.pivot.labels.AbstractLabelGeneratorBuilder.buildLabelFor(AbstractLabelGeneratorBuilder.java:44)
at org.eclipse.ocl.pivot.labels.LabelGeneratorRegistry.labelFor(LabelGeneratorRegistry.java:300)
at org.eclipse.ocl.pivot.utilities.NameUtil.qualifiedNameFor(NameUtil.java:173)
at org.eclipse.ocl.pivot.utilities.LabelUtil.getLabel(LabelUtil.java:282)
at org.eclipse.ocl.pivot.internal.labels.LabelSubstitutionLabelProvider.getObjectLabel(LabelSubstitutionLabelProvider.java:26)
at org.eclipse.emf.ecore.util.EObjectValidator.getObjectLabel(EObjectValidator.java:103)
at org.eclipse.uml2.uml.util.UMLValidator.validate_MultiplicityConforms(UMLValidator.java:26901)
at org.eclipse.emf.ecore.util.EObjectValidator.validate_EveryMultiplicityConforms(EObjectValidator.java:579)
at org.eclipse.uml2.uml.util.UMLValidator.validateSlot(UMLValidator.java:12663)
at org.eclipse.uml2.uml.util.UMLValidator.validate(UMLValidator.java:4151)
at org.eclipse.emf.ecore.util.EObjectValidator.validate(EObjectValidator.java:324)
at org.eclipse.ocl.pivot.validation.ComposedEValidator.validate(ComposedEValidator.java:125)
at org.eclipse.papyrus.uml.service.validation.internal.OCLEValidatorAdapter.validate(OCLEValidatorAdapter.java:94)
at org.eclipse.papyrus.infra.services.validation.internal.EcoreDiagnostician.validate(EcoreDiagnostician.java:82)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:190)
at org.eclipse.papyrus.uml.service.validation.internal.UMLDiagnostician.validate(UMLDiagnostician.java:143)
at org.eclipse.emf.ecore.util.Diagnostician.doValidateContents(Diagnostician.java:313)
at org.eclipse.papyrus.uml.service.validation.internal.UMLDiagnostician.doValidateContents(UMLDiagnostician.java:110)
at org.eclipse.papyrus.infra.services.validation.internal.EcoreDiagnostician.validate(EcoreDiagnostician.java:85)
at org.eclipse.emf.ecore.util.Diagnostician.doValidateContents(Diagnostician.java:309)
at org.eclipse.papyrus.uml.service.validation.internal.UMLDiagnostician.validate(UMLDiagnostician.java:122)
at org.eclipse.papyrus.infra.services.validation.commands.AbstractValidateCommand.validate(AbstractValidateCommand.java:228)
at org.eclipse.papyrus.infra.services.validation.commands.ValidationOperation.run(ValidationOperation.java:58)
at org.eclipse.papyrus.infra.ui.util.TransactionUIHelper$2.run(TransactionUIHelper.java:120)
at org.eclipse.emf.transaction.impl.PrivilegedRunnable.run(PrivilegedRunnable.java:87)
at org.eclipse.papyrus.infra.ui.util.TransactionUIHelper$PrivilegedRunnableWithProgress.run(TransactionUIHelper.java:158)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:122)
Root exception:
FUDForum. Page generated in 0.04068 seconds
