Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » 4DIAC 1.13.0 IDE(Issues with the UI working)
4DIAC 1.13.0 IDE [message #1834750] Tue, 17 November 2020 06:16 Go to next message
Just wondering if you could help me with the 1.13.0 IDE, I seem to be having various issues with getting it working.
I downloaded the IDE from the web site since I noticed that it now comes packaged with the correct version of java.
http://www.eclipse.org/downloads/download.php?file=/4diac/releases/1.13/4diac-ide/4diac-ide-incubation_1.13.0-win32.win32.x86_64.zip
Some issues I am having:
  • The monitor/watch for debugging does not work correctly at times
  • Mapping FB to EMB_RES does not work correctly at times
  • The linework does not display correctly at times (close/open IDE usually fixes the issue)
  • The FB code generated from the latest IDE will not compile with C++04 compiler (not a big issue, I can use the old IDE to generate FB changes and we don't need to do this very often)
  • Export fboot window is blank and export is not possible
Here is an example of the export to fboot:
index.php/fa/39318/0/
What am I missing with successfully running the IDE?
Thank you
Re: 4DIAC 1.13.0 IDE [message #1834765 is a reply to message #1834750] Tue, 17 November 2020 08:56 Go to previous messageGo to next message
I'm not happy to hear that. Please see some answers below.
NOJA Power wrote on Tue, 17 November 2020 11:16
Can you be more specific what is not working. I have not noticed issues here. Is there any output in the .log file.
Yes we noticed that. We have introduced an automatic layout algorithm with 1.13.0. You can test that by context menu entry layout the diagrams. Unfortunately we haven't yet managed to align the new layouting with the old routing leading sometimes to not so nice results.
As posted already we are on our way to enhance 4diac FORTE to more modern C++. We try our best to be backwards compatible and therefore happy for feedback.
We just recently noticed that we broke this: https://bugs.eclipse.org/bugs/show_bug.cgi?id=568326
Working on it to get it fixed soon.
Re: 4DIAC 1.13.0 IDE [message #1834789 is a reply to message #1834765] Tue, 17 November 2020 20:46 Go to previous messageGo to next message
In relation to the following items:
I can reliably reproduce the issue as follows:
Unpack the ide zip file. The following message is displayed and I click skip:
index.php/fa/39327/0/
Create some application (this is just an example application, it is not intended to be a useful application). Select some of the function blocks and map to EMB_RES. You can see that only one FB mapped successfully and the linework looks odd.
index.php/fa/39326/0/
Open the EMB_RES and there is the one mapped FB that worked and also a stray function block. The mapped FB can be unmapped. The stray FB needs to be deleted, it can't be unmapped.
index.php/fa/39325/0/
The .log file is attached.
In relation to:
I can't get past the first issue at the moment. Once I can I'll add some details here.
Re: 4DIAC 1.13.0 IDE [message #1834791 is a reply to message #1834789] Tue, 17 November 2020 23:19 Go to previous messageGo to next message
I tried mapping FB's to EMB_RES again following different steps and I got a little further.
  • Delete workspace and IDE from previous test
  • Unzip IDE to a short path. I tried C:\4diac-ide\ and this time no error during unzip
  • Create application with a few function blocks and map a few FB's from application to EMB_RES
This time the mapping was successful. Some of the linework shows as dashed when it should be a solid line.
index.php/fa/39328/0/
When I open EMB_RES, there is an exception fault.
index.php/fa/39329/0/
I have also attached the .log file from this test. I'll keep trying.
Re: 4DIAC 1.13.0 IDE [message #1834792 is a reply to message #1834791] Wed, 18 November 2020 00:05 Go to previous messageGo to next message
Ok, I managed to get past the last issue. This issue is to do with 'monitor' behaviour. These are the steps I took:
  • Continue from last test (previous post)
  • Unmap all
  • ctrl-a in App tab to select all FB's and map to EMB_RES
  • Open EMB_RES, mapping worked
  • Enable disable monitoring on EMB_RES tab a few times, add and remove watch from various FB's
  • Switch to application tab, no watches are available (which are enabled on EMB_RES tab)
  • Enable watches on FB in App tab that already has a watch enabled on EMB_RES tab
  • Switch to EMB_RES tab, the watch on the EMB_RES tab is frozen
  • Clear all watches on all tabs
  • Disable and enable monitor
  • Switch to App tab, enable monitor and watch on FB's
  • Switch to EMB_RES tab to see remnants from App tab
This is the App tab showing the watched. The linework is dashed but should be solid.
index.php/fa/39332/0/
This is the EMB_RES tab showing remnants from App tab.
index.php/fa/39333/0/
Latest .log file attached, looks like it might have a few more exception faults?
If I come across any other examples, I'll post them here.
Re: 4DIAC 1.13.0 IDE [message #1834798 is a reply to message #1834792] Wed, 18 November 2020 02:55 Go to previous message
Wow. thanks for the detailed feedback. I must say the forum is not a very good place to handle so many different things in one place. But I'll try to answer a view things.
First of all thanks for the log files these help a lot to narrow down your issues.
Regarding the path issue. This is a general Windows problem which we can do very little about it.
One mapping issue has already been fixed and will be available in the upcoming 1.13.1 release. We still have to look into the issue that connections are not drawn correctly all the time. This seems to happen only on Windows machines.
The monitoring thingy will be a bigger thing to look into. There we have some major changes in the internal data structures that have to be rethought.
Previous Topic:Timer function block accuracy
Next Topic:Creating an external event handler
Current Time: Sun Jul 27 12:03:17 EDT 2025
Powered by FUDForum. Page generated in 0.05102 seconds
