Home » Language IDEs » ServerTools (WTP) » Geronimo deployement plan editor does not work!?!
Geronimo deployement plan editor does not work!?! [message #183350] Tue, 28 November 2006 09:12 Go to next message
I am trying to add the axis library as dependency to my application,
because compilation of the JSP's for the generated test client always
fails stating that class org.apache.axis.AxisFault can not be found.
After clicking the Add-button on the deployment configuration tab I get
a dialog. When - after entering the data - I click Finish nothing
happens. The dialog remains and the .xml file remains as it was. When I
hit finish again, the dialog disappears but the XML file still remains
unchanged.
Seems like a bug to me or is this thing testing or checking something
and thus maybe refusing to modify anything?
Michael
Re: Geronimo deployement plan editor does not work!?! [message #183360 is a reply to message #183350] Tue, 28 November 2006 10:11 Go to previous messageGo to next message
And the reason is:
Unhandled event loop exception
java.lang.ArrayStoreException
at org.eclipse.emf.common.util.BasicEList.assign(BasicEList.jav a:188)
at
org.eclipse.emf.common.util.BasicEList.addUnique(BasicEList. java:619)
at
org.eclipse.emf.common.notify.impl.NotifyingListImpl.doAddUn ique(NotifyingListImpl.java:323)
at
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java:280)
at org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:6 00)
at
org.apache.geronimo.st.v11.ui.wizards.DependencyWizard.perfo rmFinish(DependencyWizard.java:241)
at
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:680)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:355)
at org.eclipse.jface.dialogs.Dialog$3.widgetSelected(Dialog.jav a:660)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at
org.apache.geronimo.st.ui.sections.AbstractTableSection$3.wi dgetSelected(AbstractTableSection.java:217)
at
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:64)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:615)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
"Michael Moser" <mmo@zurich.ibm.com> wrote in message
news:ekhg54$i8t$1@utils.eclipse.org...
>unchanged.
> Michael
Re: Geronimo deployement plan editor does not work!?! [message #183399 is a reply to message #183360] Tue, 28 November 2006 13:38 Go to previous messageGo to next message
Yes, that is a bug... could you open a defect at..
http://issues.apache.org/jira/browse/GERONIMODEVTOOLS
Michael Moser wrote:
> And the reason is:
> at org.eclipse.emf.common.util.BasicEList.addUnique(BasicEList. java:619)
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
> at
> at
> at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
> at
> at
> at
> at
> at
> at
> at
>> get a dialog. When - after entering the data - I click Finish nothing
>> I hit finish again, the dialog disappears but the XML file still
>> remains unchanged.
>> Michael
Re: Geronimo deployement plan editor does not work!?! [message #183415 is a reply to message #183399] Tue, 28 November 2006 15:30 Go to previous messageGo to next message
Should be fixed in daily drivers. See..
http://people.apache.org/dist/geronimo/eclipse/unstable/
>> And the reason is:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>>> remains unchanged.
>>> Michael
Re: Geronimo deployement plan editor does not work!?! [message #183421 is a reply to message #183415] Wed, 29 November 2006 04:46 Go to previous messageGo to next message
Nope - it isn't. Just downloaded the latest and same
ArrayStoreException. Filing a defect...
Michael
"Sachin Patel" <sppatel2@gmail.com> wrote in message
news:eki69f$m3k$1@utils.eclipse.org...
>>> And the reason is:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>>> application, because compilation of the JSP's for the generated
>>>> test client always fails stating that class
>>>> org.apache.axis.AxisFault can not be found. After clicking the
>>>> Add-button on the deployment configuration tab I get a dialog.
>>>> When - after entering the data - I click Finish nothing happens.
>>>> The dialog remains and the .xml file remains as it was. When I hit
>>>> unchanged.
>>>> something and thus maybe refusing to modify anything?
>>>> Michael
Re: Geronimo deployement plan editor does not work!?! [message #183445 is a reply to message #183421] Wed, 29 November 2006 09:34 Go to previous messageGo to next message
When you extracted the daily driver did you relaunch eclipse with "-clean"?
> Michael
>>>> And the reason is:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>>> Add-button on the deployment configuration tab I get a dialog. When
>>>>> - after entering the data - I click Finish nothing happens. The
>>>>> unchanged.
>>>>> Michael
Re: Geronimo deployement plan editor does not work!?! [message #183452 is a reply to message #183445] Wed, 29 November 2006 09:46 Go to previous messageGo to next message
Yes - I ALWAYS start eclipse with -clean.
I grew accustomed to that habit since I change and experiment with my
configs a lot and also have multiple eclipse versions running. So, all
my shortcuts have a -clean option. And if everything else fails I even
re-start with a fresh configuration directory...
Michael
news:ekk5pt$r4a$1@utils.eclipse.org...
> "-clean"?
>> Michael
>>>>> And the reason is:
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>>> remains unchanged.
>>>>>> Michael
Re: Geronimo deployement plan editor does not work!?! [message #183577 is a reply to message #183452] Thu, 30 November 2006 05:37 Go to previous message
See my latest findings at
http://issues.apache.org/jira/browse/GERONIMODEVTOOLS-117?pa ge=comments#action_12454572
Michael
Previous Topic:Undo/Redo in XML Multipage Editor
Next Topic:XML, XHTML editing, indenting
Current Time: Sat Jul 26 15:19:47 EDT 2025
Powered by FUDForum. Page generated in 0.10287 seconds
