Kura unset emulator [message #1834418] |
Tue, 10 November 2020 00:05  |
2020-11-09T23:02:47,623 [Start Level: Equinox Container: 70a2bae5-4f78-4fac-b44c-769902787e41] INFO o.a.c.i.o.Activator - Camel activator starting
2020-11-09T23:02:47,640 [Start Level: Equinox Container: 70a2bae5-4f78-4fac-b44c-769902787e41] INFO o.a.c.i.o.Activator - Camel activator started
osgi> 2020-11-09T23:02:48,686 [Start Level: Equinox Container: 70a2bae5-4f78-4fac-b44c-769902787e41] INFO o.e.j.u.log - Logging initialized @2936ms to org.eclipse.jetty.util.log.Slf4jLog
!SESSION 2020-11-09 23:02:46.069 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_102
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_IN
Command-line arguments: -dev file:/Users/sanif/kura/.metadata/.plugins/org.eclipse.pde.core/Kura_Emulator_OSX/dev.properties -os macosx -ws cocoa -arch x86_64 -consoleLog -console
!ENTRY org.eclipse.equinox.http.jetty 4 0 2020-11-09 23:02:48.950
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.equinox.http.jetty.internal.Activator.start() of bundle org.eclipse.equinox.http.jetty.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:800)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:729)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:933)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309)
at org.eclipse.osgi.container.Module.doStart(Module.java:581)
at org.eclipse.osgi.container.Module.start(Module.java:449)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
Caused by: org.osgi.service.cm.ConfigurationException: default : Failed to bind to 0.0.0.0/0.0.0.0:8080
at org.eclipse.equinox.http.jetty.internal.HttpServerManager.updated(HttpServerManager.java:92)
at org.eclipse.equinox.http.jetty.internal.Activator.start(Activator.java:62)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:779)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:772)
... 12 more
Caused by: java.io.IOException: Failed to bind to 0.0.0.0/0.0.0.0:8080
at org.eclipse.jetty.server.ServerConnector.openAcceptChannel(ServerConnector.java:346)
at org.eclipse.jetty.server.ServerConnector.open(ServerConnector.java:308)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager.updated(HttpServerManager.java:90)
... 17 more
Caused by: java.net.BindException: Address already in use
at sun.nio.ch.Net.bind0(Native Method)
at sun.nio.ch.Net.bind(Net.java:433)
at sun.nio.ch.Net.bind(Net.java:425)
at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:223)
at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:74)
at org.eclipse.jetty.server.ServerConnector.openAcceptChannel(ServerConnector.java:342)
... 19 more
Root exception:
... 17 more
... 19 more
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:48.978
!MESSAGE [org.eclipse.kura.net.NetworkService(30)] bind method [setEmulator] not found; Component will fail
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.003
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.005
!MESSAGE [org.eclipse.kura.net.NetworkService(30)] activate method [activate] not found; Component will fail
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.006
!MESSAGE [org.eclipse.kura.net.NetworkService(30)] unbind method [unsetEmulator] not found; Component will fail
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.082
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.083
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.108
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.109
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.143
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.144
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.151
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.178
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.179
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.184
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.185
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.186
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.211
!ENTRY org.eclipse.kura.emulator 4 0 2020-11-09 23:02:49.358
!STACK 0
org.osgi.framework.ServiceException: Exception in org.apache.felix.scr.impl.manager.SingleComponentManager.getService()
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:222)
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111)
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461)
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624)
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:1)
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)
at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:183)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:318)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:261)
at com.eclipsesource.jaxrs.publisher.internal.Activator.openAllServiceTracker(Activator.java:91)
at com.eclipsesource.jaxrs.publisher.internal.Activator.start(Activator.java:55)
Caused by: java.lang.UnsupportedClassVersionError: org/eclipse/kura/emulator/Emulator has been compiled by a more recent version of the Java Runtime (class file version 58.0), this version of the Java Runtime only recognizes class file versions up to 52.0
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:763)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.defineClass(ModuleClassLoader.java:276)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.defineClass(ClasspathManager.java:655)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:578)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:538)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:525)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:328)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:368)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:446)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:564)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.initDependencyManagers(AbstractComponentManager.java:976)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:1003)
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:859)
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:823)
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212)
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210)
... 30 more
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.486
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.490
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.492
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.498
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.513
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.519
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.521
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.522
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.524
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.525
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.528
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.530
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.536
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.537
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.541
!ENTRY org.eclipse.kura.emulator.net 4 0 2020-11-09 23:02:49.542
!ENTRY org.eclipse.osgi 4 0 2020-11-09 23:02:49.577
!MESSAGE Bundle org.eclipse.equinox.http.jetty_3.4.0.v20170503-2025 [92] is not active.
Re: Kura unset emulator [message #1834481 is a reply to message #1834469] |
Wed, 11 November 2020 02:56  |
The error reported are two, from what I see from the logs: one is about the impossibility to bind to the specified port with a "port in use exception", the other is related to the JVM used: "Caused by: java.lang.UnsupportedClassVersionError: org/eclipse/kura/emulator/Emulator has been compiled by a more recent version of the Java Runtime (class file version 58.0), this version of the Java Runtime only recognizes class file versions up to 52.0".
It seems that you are trying to run kura on a newer version than Java 8.
Matteo
FUDForum. Page generated in 0.05917 seconds
