Arrowhead framework & Registering Services [message #1834451] |
Tue, 10 November 2020 09:33  |
Hi All,
I am looking to Register the end point URL addresses of OPC UA for Client and publish blocks to AF?
e.g. opc_ua[opc.tcp://localhost:IP#/Objects/2:PLC1/2:eq_states/2:EQ_V102]
I am using this procedure to first test the application and if it works will implement the orchestrator for the service.
What should be the entries of the fields?
Using e.g. (IP:PORT/serviceregistry/mgmt/id) as address. The id is 22. primarily, using POSTMAN to register the services.
"id": 22,
"serviceDefinition": {
"id": 23,
"serviceDefinition": "valve102",
"createdAt": "2020-01-27 13:15:40",
"updatedAt": "2020-01-27 13:15:40"
"provider": {
"id": 14,
"systemName": "NAME",
"address": "iec61499",
"port": 0,
"authenticationInfo": "string",
"createdAt": "2020-01-27 12:35:27",
"updatedAt": "2020-01-27 12:35:27"
"serviceUri": "opc_ua[opc.tcp://localhost:IP#/Objects/2:PLC1/2:eq_states/2:EQ_V102]",
"secure": "NOT_SECURE",
"metadata": {},
"version": 0,
"interfaces": [
"id": 3,
"interfaceName": "HTTPS-SECURE-JSON",
"createdAt": "2019-12-27 06:45:42",
"updatedAt": "2019-12-27 06:45:42"
According the documentation, 4diac is not compatible with 4.1.3, only with 4.1.2?
First steps are to correctly Register the end point URL addresses of OPC UA, than those services can be used in 4Diac function blocks to run my application.
Thanks in advance.
BR,
Ahsan
FUDForum. Page generated in 0.03516 seconds
