Home » Newcomers » Newcomers » Error occurs when installing extension software
Error occurs when installing extension software [message #1834407] Mon, 09 November 2020 16:20
When I finished downloading programming languages and general tools from ''Oxygen -
http://download.eclipse.org/releases/oxygen'' on my eclipse and tried to launch it, an error message said '' an error has occurred. See the log file". In the log file, it shows "!ENTRY org.eclipse.ecf.provider.filetransfer.httpclient45.win32 4 0 2020-11-09 13:12:54.849
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.ecf.provider.filetransfer.httpclient45.win32 [209]
Unresolved requirement: Import-Package: org.apache.http.impl.client; version="[4.5.0,5.0.0)"
-> Export-Package: org.apache.http.impl.client; bundle-symbolic-name="org.apache.httpcomponents.httpclient"; bundle-version="4.5.10.v20200114-1512"; version="4.5.10"; uses:="javax.net.ssl,org.apache.commons.logging,org.apache.http,org.apache.http.auth,org.apache.http.client,org.apache.http.client.config,org.apache.http.client.entity,org.apache.http.client.methods,org.apache.http.concurrent,org.apache.http.config,org.apache.http.conn,org.apache.http.conn.routing,org.apache.http.conn.socket,org.apache.http.conn.ssl,org.apache.http.conn.util,org.apache.http.cookie,org.apache.http.impl,org.apache.http.impl.auth,org.apache.http.impl.execchain,org.apache.http.message,org.apache.http.params,org.apache.http.pool,org.apache.http.protocol"
org.apache.httpcomponents.httpclient [68]
Unresolved requirement: Import-Package: org.apache.commons.codec.binary; version="[1.13.0,1.14.0)"
Unresolved requirement: Import-Package: org.apache.http.auth; version="[4.5.0,5.0.0)"
-> Export-Package: org.apache.http.auth; bundle-symbolic-name="org.apache.httpcomponents.httpclient"; bundle-version="4.5.10.v20200114-1512"; version="4.5.10"; uses:="org.apache.http,org.apache.http.config,org.apache.http.params,org.apache.http.protocol,org.ietf.jgss"
Unresolved requirement: Import-Package: org.apache.http.client.config; version="[4.5.0,5.0.0)"
-> Export-Package: org.apache.http.client.config; bundle-symbolic-name="org.apache.httpcomponents.httpclient"; bundle-version="4.5.10.v20200114-1512"; version="4.5.10"; uses:="org.apache.http"
Unresolved requirement: Import-Package: org.apache.http.impl.auth.win; version="[4.5.0,5.0.0)"
-> Export-Package: org.apache.http.impl.auth.win; bundle-symbolic-name="org.apache.httpcomponents.httpclient.win"; bundle-version="4.5.10.v20200113-2105"; version="4.5.10"; x-internal:="true"; uses:="org.apache.http,org.apache.http.auth,org.apache.http.client,org.apache.http.impl.auth,org.apache.http.protocol,org.apache.http.util"
org.apache.httpcomponents.httpclient.win [69]
Unresolved requirement: Import-Package: org.apache.http.client.protocol; version="[4.5.10,4.6.0)"
-> Export-Package: org.apache.http.client.protocol; bundle-symbolic-name="org.apache.httpcomponents.httpclient"; bundle-version="4.5.10.v20200114-1512"; version="4.5.10"; uses:="org.apache.http,org.apache.http.auth,org.apache.http.client,org.apache.http.client.config,org.apache.http.client.entity,org.apache.http.config,org.apache.http.conn.routing,org.apache.http.cookie,org.apache.http.protocol"
Unresolved requirement: Import-Package: org.apache.http.conn.routing; version="[4.5.10,4.6.0)"
-> Export-Package: org.apache.http.conn.routing; bundle-symbolic-name="org.apache.httpcomponents.httpclient"; bundle-version="4.5.10.v20200114-1512"; version="4.5.10"; uses:="org.apache.http,org.apache.http.protocol"
Unresolved requirement: Import-Package: org.apache.http.client; version="[4.5.10,4.6.0)"
-> Export-Package: org.apache.http.client; bundle-symbolic-name="org.apache.httpcomponents.httpclient"; bundle-version="4.5.10.v20200114-1512"; version="4.5.10"; uses:="org.apache.http,org.apache.http.auth,org.apache.http.client.methods,org.apache.http.conn,org.apache.http.conn.routing,org.apache.http.cookie,org.apache.http.params,org.apache.http.protocol"
Unresolved requirement: Import-Package: org.apache.http.auth; version="[4.5.10,4.6.0)"
Unresolved requirement: Import-Package: org.apache.http.impl.auth; version="[4.5.10,4.6.0)"
-> Export-Package: org.apache.http.impl.auth; bundle-symbolic-name="org.apache.httpcomponents.httpclient"; bundle-version="4.5.10.v20200114-1512"; version="4.5.10"; uses:="org.apache.commons.logging,org.apache.http,org.apache.http.auth,org.apache.http.client,org.apache.http.params,org.apache.http.protocol,org.apache.http.util,org.ietf.jgss"
Unresolved requirement: Import-Package: org.apache.http.client.protocol; version="[4.5.0,5.0.0)"
Unresolved requirement: Import-Package: org.apache.http.client; version="[4.5.0,5.0.0)"
Unresolved requirement: Import-Package: org.apache.http.impl.auth; version="[4.5.0,5.0.0)"
at org.eclipse.osgi.container.Module.start(Module.java:463)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1845)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1838)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1779)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1743)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1665)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345)
!ENTRY org.eclipse.epp.mpc.core.win32 4 0 2020-11-09 13:12:54.867
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.epp.mpc.core.win32 [224]
Unresolved requirement: Import-Package: org.apache.http.impl.client; version="4.3.6"
Unresolved requirement: Import-Package: org.apache.http.impl.auth; version="4.3.6"
Unresolved requirement: Import-Package: org.apache.http.impl.auth.win; version="4.3.6"
Unresolved requirement: Import-Package: org.apache.http.auth; version="4.3.6"
Unresolved requirement: Import-Package: org.apache.http.client.config; version="4.3.6"
Unresolved requirement: Import-Package: org.apache.http.client; version="4.3.6"
!ENTRY org.eclipse.dltk.core.index.lucene 4 0 2020-11-09 13:12:55.842
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.dltk.core.index.lucene [667]
Unresolved requirement: Require-Bundle: org.apache.lucene.misc; bundle-version="6.1.0"
-> Bundle-SymbolicName: org.apache.lucene.misc; bundle-version="6.1.0.v20161115-1612"
org.apache.lucene.misc [626]
Bundle was not resolved because of a uses constraint violation.
org.apache.felix.resolver.reason.ReasonException: Uses constraint violation. Unable to resolve resource org.apache.lucene.misc [osgi.identity; osgi.identity="org.apache.lucene.misc"; type="osgi.bundle"; version:Version="6.1.0.v20161115-1612"] because it exports package 'org.apache.lucene.document' and is also exposed to it from resource org.apache.lucene.core [osgi.identity; type="osgi.bundle"; version:Version="6.1.0.v20170814-1820"; osgi.identity="org.apache.lucene.core"] via the following dependency chain:
import: (&(osgi.wiring.package=org.apache.lucene.analysis)(&(version>=6.1.0)(!(version>=6.2.0))))
export: osgi.wiring.package: org.apache.lucene.analysis; uses:=org.apache.lucene.document
export: osgi.wiring.package=org.apache.lucene.document
!ENTRY org.eclipse.ui 4 0 2020-11-09 13:12:58.156
!STACK 0
java.lang.ClassFormatError: Unexpected error from weaving hook.
at org.eclipse.osgi.internal.weaving.WeavingHookConfigurator.processClass(WeavingHookConfigurator.java:86)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.processClass(ClasspathManager.java:737)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.defineClass(ClasspathManager.java:708)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:641)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:609)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:589)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:568)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:346)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:398)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:477)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:171)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:522)
at org.eclipse.ui.PlatformUI.isWorkbenchRunning(PlatformUI.java:119)
at org.eclipse.ui.plugin.AbstractUIPlugin.refreshPluginActions(AbstractUIPlugin.java:535)
at org.eclipse.ui.plugin.AbstractUIPlugin$1.bundleChanged(AbstractUIPlugin.java:651)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:945)
Caused by: java.lang.IllegalArgumentException
at org.objectweb.asm.ClassReader.<init>(ClassReader.java:160)
at org.objectweb.asm.ClassReader.<init>(ClassReader.java:143)
at org.objectweb.asm.ClassReader.<init>(ClassReader.java:418)
at org.eclipse.objectteams.internal.osgi.weaving.ASMByteCodeAnalyzer.getClassInformation(ASMByteCodeAnalyzer.java:103)
at org.eclipse.objectteams.internal.osgi.weaving.ASMByteCodeAnalyzer.getClassInformation(ASMByteCodeAnalyzer.java:82)
at org.eclipse.objectteams.internal.osgi.weaving.OTWeavingHook.isAdaptedBaseClass(OTWeavingHook.java:405)
at org.eclipse.objectteams.internal.osgi.weaving.OTWeavingHook.isAdaptedBaseClass(OTWeavingHook.java:414)
at org.eclipse.objectteams.internal.osgi.weaving.OTWeavingHook.requiresWeaving(OTWeavingHook.java:359)
at org.eclipse.objectteams.internal.osgi.weaving.OTWeavingHook.weave(OTWeavingHook.java:268)
at org.eclipse.osgi.internal.weaving.WovenClassImpl.call(WovenClassImpl.java:187)
at org.eclipse.osgi.internal.weaving.WovenClassImpl.call(WovenClassImpl.java:1)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.notifyHookPrivileged(ServiceRegistry.java:1338)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.notifyHooksPrivileged(ServiceRegistry.java:1311)
at org.eclipse.osgi.internal.weaving.WovenClassImpl.callHooks(WovenClassImpl.java:252)
at org.eclipse.osgi.internal.weaving.WeavingHookConfigurator.processClass(WeavingHookConfigurator.java:80)
... 17 more
!ENTRY org.apache.felix.scr 4 0 2020-11-09 13:12:58.417
!MESSAGE bundle org.apache.felix.scr:2.1.16.v20200110-1820 (66)Error while disposing components of bundle org.eclipse.core.resources:3.13.800.v20200706-2152 (174)
!STACK 0
java.lang.IllegalStateException: BundleContext is no longer valid org.eclipse.core.resources_3.13.800.v20200706-2152 [174]
at org.eclipse.osgi.internal.framework.BundleContextImpl.checkValid(BundleContextImpl.java:1027)
at org.eclipse.osgi.internal.framework.BundleContextImpl.ungetService(BundleContextImpl.java:697)
at org.apache.felix.scr.impl.logger.LogServiceEnabledLogger$1.removedService(LogServiceEnabledLogger.java:79)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:969)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:1)
at org.osgi.util.tracker.AbstractTracked.untrack(AbstractTracked.java:341)
at org.osgi.util.tracker.ServiceTracker.close(ServiceTracker.java:380)
at org.apache.felix.scr.impl.logger.LogServiceEnabledLogger.close(LogServiceEnabledLogger.java:91)
at org.apache.felix.scr.impl.logger.BundleLogger.close(BundleLogger.java:28)
at org.apache.felix.scr.impl.BundleComponentActivator.dispose(BundleComponentActivator.java:531)
at org.apache.felix.scr.impl.Activator.disposeComponents(Activator.java:429)
at org.apache.felix.scr.impl.Activator.access$300(Activator.java:49)
at org.apache.felix.scr.impl.Activator$ScrExtension.destroy(Activator.java:292)
at org.apache.felix.scr.impl.AbstractExtender$1.run(AbstractExtender.java:216)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at org.apache.felix.scr.impl.AbstractExtender.destroyExtension(AbstractExtender.java:238)
at org.apache.felix.scr.impl.AbstractExtender.bundleChanged(AbstractExtender.java:132)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:232)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:138)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:130)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:217)
at org.eclipse.osgi.container.Module.publishEvent(Module.java:499)
at org.eclipse.osgi.container.Module.doStart(Module.java:611)
at org.eclipse.osgi.container.Module.start(Module.java:468)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:506)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:117)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:572)
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:41)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:473)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:564)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
!ENTRY org.eclipse.osgi 4 0 2020-11-09 13:12:58.428
!MESSAGE An error occurred while automatically activating bundle org.eclipse.core.resources (174).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:835)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:763)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:1011)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:365)
at org.eclipse.osgi.container.Module.doStart(Module.java:605)
at org.eclipse.core.internal.resources.CharsetDeltaJob.startup(CharsetDeltaJob.java:212)
at org.eclipse.core.internal.resources.CharsetManager.startup(CharsetManager.java:505)
at org.eclipse.core.internal.resources.Workspace.startup(Workspace.java:2456)
at org.eclipse.core.internal.resources.Workspace.open(Workspace.java:2210)
at org.eclipse.core.resources.ResourcesPlugin.start(ResourcesPlugin.java:489)
at org.eclipse.osgi.internal.framework.BundleContextImpl$2.run(BundleContextImpl.java:814)
at org.eclipse.osgi.internal.framework.BundleContextImpl$2.run(BundleContextImpl.java:1)
at java.base/java.security.AccessController.doPrivileged(AccessController.java:554)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:806)
... 27 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2020-11-09 13:12:58.465
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/eclipse/core/resources/IContainer
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.core.resources (174).
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:126)
... 13 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
... 20 more
... 27 more"
Anyone get any clue how to fix it?
Previous Topic:How do I view hidden files in eclipse?
Next Topic:error installing eclipse kura
Current Time: Mon Jul 21 07:23:02 EDT 2025
Powered by FUDForum. Page generated in 0.08139 seconds
