CSS reference element selector [message #1834001] |
Thu, 29 October 2020 14:48  |
Hi all,
I'm trying to write a CSS selector for accessing a child member of a Reference. As I prior never worked with CSS I don't really know how the selectors work/work inside Papyrus.
I have a Stereotype called Reference applied to a Generalization. This stereotype has a member called referenceType which is of ReferenceType and based on the used ReferenceType I want to change the visuals of the Generalization, e.g. if "isSymmetric" is set to true, there shall be arrows on both sides.
I managed to access the members of Reference but not of the referenced ReferenceType.
Here https://wiki.eclipse.org/MDT/Papyrus/UserGuide/CSS#Selector_properties is written that I should be able to access the reference, but I don't really understand how.
Quote:References to named elements (UML NamedElement or Ecore ENamedElement): [type=String]
I found the following forum post but I don't understand it https://www.eclipse.org/forums/index.php?t=msg&th=664574&goto=1278528&#msg_1278528
Optionally I want to display text which is stored inside a ReferenceType on the Generalization, is this somehow possible?
Thanks for your help.
BR Christoph
[Updated on: Thu, 29 October 2020 14:52] by Moderator
Re: CSS reference element selector [message #1834013 is a reply to message #1834001] |
Fri, 30 October 2020 04:05   |
Hi Christoph,
CSS don't support properties navigation as any programming language would. You can only check the value of one property at a time. In Papyrus, we added some support for references to NamedElements, but that's limited to one level.
For example, if you have a Property typed with a Class named String, you can write the following rules:
Property[isStatic=true]{ // Standard primitive types
Property[type=String]{ // References to NamedElements
However, you can't write rules that require navigating the references, such as:
Property[type.isAbstract=true] { // Any property typed with an abstract classifier
// Not a valid rule
There are a few cases where we implemented custom properties to workaround this issue, such as the "typeAppliedStereotypes" which can be used to test that a specific Stereotype is applied to a Type, from a TypedElement (e.g. Property); but this isn't really recommended:
Property[typeAppliedStereotypes=Block] { // A Property typed with a Classifier that is stereotyped with a Block.
// Valid rule, but requires custom implementation of the typeAppliedStereotypes property
Quote:Optionally I want to display text which is stored inside a ReferenceType on the Generalization, is this somehow possible?
This is beyond the scope of CSS; you would have to extend the Diagram(s) for that.
HTH,
Camille
Re: CSS reference element selector [message #1834015 is a reply to message #1834013] |
Fri, 30 October 2020 04:48  |
Hi Camille,
thanks for you answer.
Then I will have to find some workaround on providing the data to the stereotype application.
Is there a way to display anything on a generalization except in comments?
As a workaround I try to only view certain stereotype members in the comment. Is it possible to write a CSS selector which only applies to Comments of Generalizaitons?
[Updated on: Fri, 30 October 2020 06:03] by Moderator
FUDForum. Page generated in 0.06165 seconds
