Home » Newcomers » Newcomers » [SOLVED] User sees update available from shared installation, but admin user does not(Can a user upgrade the a "shared" feature into their writable area)
[SOLVED] User sees update available from shared installation, but admin user does not [message #1833821] Sat, 24 October 2020 19:35 Go to next message
I have two somewhat related problems with using a shared installation:
1. When I use a admin user that has write permissions to the shared area, the admin user doesn't see the Update as available - this surprises me.
Specifically:
User: shared/eclipse -configuration ~/eclipse/configuration
This user is seeing
Node.js embedder from Wild Web Developer
Wild Web Developer
has updates with Insufficient Access
Root user: shared/eclipse
...does not see any updates
Before I solve the user-can-see-update-but-admin-user cannot problem:
How can this user install the later version into their writable configuration folder ; i.e. "masking" the version from the shared installation - is ok in this context. We allow users to have their own set of plugins.
[Updated on: Sat, 24 October 2020 22:11] by Moderator
Re: [SOLVED] User sees update available from shared installation, but admin user does not [message #1833825 is a reply to message #1833821] Sat, 24 October 2020 22:15 Go to previous message
I solved the user-can-see-update-but-admin-cannot: not sure why but "Check for Updates" and Help->Eclipse Marketplace...->Installed.. are not quite in sync.
With the admin user, Wild Web Developer update is available via the Marketplace->Installed workflow.
With the normal user, the update is available via the "Check for Updates" workflow...
After updating the shared folder with the admin user, they both see the same state.
[Updated on: Sat, 24 October 2020 22:16] by Moderator
Previous Topic:What happens when a user-installed feature is subsequently installed to the shared installation?
Next Topic:Jakarta ee web project
Current Time: Fri Jul 25 23:41:04 EDT 2025
Powered by FUDForum. Page generated in 0.09566 seconds
