Home » Newcomers » Newcomers » Error starting Aptana(Aptana 3)
Error starting Aptana [message #1833813] Sat, 24 October 2020 10:24 Go to next message
I get "An error has occurred" starting Aptana 3, point me at the log file. This gives:
!SESSION 2020-10-24 14:19:20.685 -----------------------------------------------
eclipse.buildId=unknown
java.version=11.0.8
java.vendor=Ubuntu
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_GB
Command-line arguments:  -os linux -ws gtk -arch x86_64
!ENTRY org.eclipse.osgi 4 0 2020-10-24 14:19:22.381
!MESSAGE Application error
!STACK 1
org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:410)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:318)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultHeadlessContext(E4Application.java:491)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:505)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:204)
	at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:614)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
	at com.aptana.rcp.IDEApplication.start(IDEApplication.java:126)
	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.base/java.lang.reflect.Method.invoke(Method.java:566)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1472)
Caused by: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:124)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:399)
	... 23 more
Caused by: java.lang.ClassNotFoundException: javax.annotation.PostConstruct cannot be found by org.eclipse.e4.core.di_1.6.100.v20170421-1418
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:433)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387)
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150)
	at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:522)
	... 25 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2020-10-24 14:19:22.386
!MESSAGE FrameworkEvent ERROR
!STACK 0
java.lang.NoClassDefFoundError: javax/annotation/PreDestroy
	at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:450)
	at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:156)
	at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:78)
	at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:111)
	at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:74)
	at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:178)
	at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:99)
	at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:141)
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213)
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120)
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112)
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168)
	at org.eclipse.osgi.container.Module.publishEvent(Module.java:476)
	at org.eclipse.osgi.container.Module.doStop(Module.java:634)
	at org.eclipse.osgi.container.Module.stop(Module.java:498)
	at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:202)
	at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:165)
	at java.base/java.lang.Thread.run(Thread.java:834)
Caused by: java.lang.ClassNotFoundException: javax.annotation.PreDestroy cannot be found by org.eclipse.e4.core.di_1.6.100.v20170421-1418
	... 21 more
Can anyone please suggest where I go from here?
Re: Error starting Aptana [message #1833814 is a reply to message #1833813] Sat, 24 October 2020 10:44 Go to previous messageGo to next message
You should probably be going through http://www.aptana.com/support.html, but off hand I'd say it's set up to be run with Java 8 and not anything newer.
Re: Error starting Aptana [message #1833815 is a reply to message #1833814] Sat, 24 October 2020 11:24 Go to previous messageGo to next message
Thanks, I'll try Aptana support. It's using Java 8 because it won't work with anything newer - I went all through that when I first installed Aptana. Unless, of course, there's now an Aptana update that will work with later Javas.
Re: Error starting Aptana [message #1833859 is a reply to message #1833815] Mon, 26 October 2020 09:13 Go to previous messageGo to next message
The log indicates it's being run with Java 11, whether on purpose or by accident.
Re: Error starting Aptana [message #1833860 is a reply to message #1833859] Mon, 26 October 2020 09:26 Go to previous messageGo to next message
So how do I force it to use Java 8 which should be installed?
Re: Error starting Aptana [message #1833868 is a reply to message #1833860] Mon, 26 October 2020 12:17 Go to previous messageGo to next message
Edit the eclipse.ini and add two lines like this before the -vmargs line:
-vm
C:/Program Files/Java/jdk1.8.0_231/jre/bin
-vmargs
Of course you're on Linux so the path will be different. Be careful of trailing spaces.
Re: Error starting Aptana [message #1834028 is a reply to message #1833868] Fri, 30 October 2020 09:42 Go to previous message
I've changed the default to Java 8 and Aptana now works correctly.
Thank you for everyone's help.
Previous Topic:Unable to retrieve the bundle from the URI
Next Topic:Eclipse SSL error server certificate might be invalid
Current Time: Mon Jul 21 04:26:52 EDT 2025
Powered by FUDForum. Page generated in 0.10726 seconds
