Home » Modeling » EMF » where to implement a ChangeRecorder
where to implement a ChangeRecorder [message #1833747] Fri, 23 October 2020 04:41 Go to next message
Hi, i have an emf model and an emf.forms editor generated..
I want to dynamically create and display a list of changes made to an EObject that includes date and changes.
I read the emf-Book and found an powerful ChangeRecorder Class that seems to be the best starting point.
I would be happy to receive hints on where to implement it.
i found a way in the Package Model Editor - for the emf.forms editor it doesn't work [message #1833910 is a reply to message #1833747] Tue, 27 October 2020 11:30 Go to previous messageGo to next message
i found a way in the Package Model Editor (the generic non-emf.forms one)
i added a Member to the ~PackageEditor Class
public ChangeRecorder changerecorder;
and initialized it in the initializeEditingDomain() - Method at the End.
after this generated line:
editingDomain = new AdapterFactoryEditingDomain(adapterFactory, commandStack, new HashMap<Resource, Boolean>());
changerecorder = new ChangeRecorder(editingDomain.getResourceSet());
..when the Save-Functions are called i can changerecorder.summarize() it and read the Changes. where the editingDomain gets disposed i dispose it too.
But i still have no idea how to get it running for the emf.forms Editor..
Can please anyone tell me ?
Re: where to implement a ChangeRecorder [message #1833914 is a reply to message #1833747] Tue, 27 October 2020 12:38 Go to previous messageGo to next message
you can attach the ChangeRecorder with beginRecording() to an EObject (and its containments) and it will record all changes and on calling endRecording() return the changes, also see here:
https://download.eclipse.org/modeling/emf/emf/javadoc/2.4.3/org/eclipse/emf/ecore/change/util/ChangeRecorder.html
Hope this helps!
Maximilian
Re: where to implement a ChangeRecorder [message #1833915 is a reply to message #1833914] Tue, 27 October 2020 12:40 Go to previous messageGo to next message
Just realized you have already posted a follow-up question. Are you referring to the EMF Forms Editor? Can you please elaborate what you are trying to do.
Maximilian
Re: where to implement a ChangeRecorder [message #1833916 is a reply to message #1833915] Tue, 27 October 2020 13:36 Go to previous message
I have Model describing a System containing some components. I generated the. Model, . Edit and. ViewModel.. Then i generated with the forms-genmodel the .Editor.
I want to fill the Attributes initially with the EMF.forms Editor, after everything is filled in i want to use the changerecorder and fill an viewable List with the changes to the System. All editing should be done with emf.forms Editor cause its so nice an conviniant.
In this article i found, that the forms Editor generates no Code..
https://eclipsesource.com/blogs/tutorials/emf-forms-editors/
I guess i have to read some more about creating a custom Editor using the. Forms Classes
org.eclipse.emfforms.spi.editor.GenericEditor
org.eclipse.emfforms.editor
Is there an Tutorial available?
Previous Topic:[CDO] Guidelines for upgrading from CDO 4.1 to 4.11
Next Topic:Source not found Edit Source Lookup Path
Current Time: Mon Jul 21 06:11:03 EDT 2025
Powered by FUDForum. Page generated in 0.06363 seconds
