Home » Newcomers » Newcomers » Installation Error
Installation Error [message #1833647] Tue, 20 October 2020 06:37 Go to next message
I tried to reinstall eclipse, because I had eclipse 2020 06 previously and wanted to install the newer version eclipse 2020 09 (for java developers). The installer shows me that the installation failed with an error.
Log:
[2020-10-20 12:31:29] Executing bootstrap tasks
[2020-10-20 12:31:29] OpenJDK Runtime Environment 14.0.2+12-46
[2020-10-20 12:31:29] Product org.eclipse.products.epp.package.java.2020-09
[2020-10-20 12:31:29] Bundle org.eclipse.oomph.setup 1.18.0.v20200820-0414, build=4828, branch=33d843c1d70f55bcaaf6421eb3af77b98e9fe9c0
[2020-10-20 12:31:29] Bundle org.eclipse.oomph.setup.core 1.18.0.v20200624-1156, build=4828, branch=33d843c1d70f55bcaaf6421eb3af77b98e9fe9c0
[2020-10-20 12:31:29] Bundle org.eclipse.oomph.setup.p2 1.16.0.v20200814-1205, build=4828, branch=33d843c1d70f55bcaaf6421eb3af77b98e9fe9c0
[2020-10-20 12:31:29] Performing P2 Director (Eclipse IDE for Java Developers (2020-09))
[2020-10-20 12:31:29] Offline = false
[2020-10-20 12:31:29] Mirrors = true
[2020-10-20 12:31:29] Resolving 16 requirements from 3 repositoriesto C:\Users\iliav\java-2020-0934\eclipse
[2020-10-20 12:31:29] Requirement org.eclipse.equinox.p2.iu:epp.package.java [4.17.0,5.0.0)
[2020-10-20 12:31:29] Requirement org.eclipse.equinox.p2.iu:org.eclipse.platform.feature.group [4.17.0,5.0.0)
[2020-10-20 12:31:29] Requirement org.eclipse.equinox.p2.iu:org.eclipse.rcp.feature.group [4.17.0,5.0.0)
[2020-10-20 12:31:29] Requirement org.eclipse.equinox.p2.iu:org.eclipse.buildship.feature.group
[2020-10-20 12:31:29] Requirement org.eclipse.equinox.p2.iu:org.eclipse.eclemma.feature.feature.group
[2020-10-20 12:31:29] Requirement org.eclipse.equinox.p2.iu:org.eclipse.egit.feature.group
[2020-10-20 12:31:29] Requirement org.eclipse.equinox.p2.iu:org.eclipse.epp.mpc.feature.group
[2020-10-20 12:31:29] Requirement org.eclipse.equinox.p2.iu:org.eclipse.jdt.feature.group
[2020-10-20 12:31:29] Requirement org.eclipse.equinox.p2.iu:org.eclipse.jgit.feature.group
[2020-10-20 12:31:29] Requirement org.eclipse.equinox.p2.iu:org.eclipse.m2e.feature.feature.group
[2020-10-20 12:31:29] Requirement org.eclipse.equinox.p2.iu:org.eclipse.m2e.lemminx.feature.feature.group
[2020-10-20 12:31:29] Requirement org.eclipse.equinox.p2.iu:org.eclipse.m2e.logback.feature.feature.group
[2020-10-20 12:31:29] Requirement org.eclipse.equinox.p2.iu:org.eclipse.mylyn.wikitext.editors_feature.feature.group
[2020-10-20 12:31:29] Requirement org.eclipse.equinox.p2.iu:org.eclipse.tips.feature.feature.group
[2020-10-20 12:31:29] Requirement org.eclipse.equinox.p2.iu:org.eclipse.wildwebdeveloper.xml.feature.feature.group
[2020-10-20 12:31:29] Requirement org.eclipse.equinox.p2.iu:org.eclipse.oomph.setup.feature.group
[2020-10-20 12:31:29] Repository http://download.eclipse.org/technology/epp/packages/2020-09/202009101200
[2020-10-20 12:31:29] Repository http://download.eclipse.org/releases/2020-09/202009161000
[2020-10-20 12:31:29] Repository http://download.eclipse.org/oomph/updates/milestone/latest
[2020-10-20 12:31:29] ERROR: org.eclipse.equinox.p2.transport.ecf code=1002 Unable to read repository at http://download.eclipse.org/oomph/updates/milestone/latest/compositeContent.xml.
java.net.SocketException: Address family not supported by protocol family: connect
at java.base/sun.nio.ch.Net.connect0(Native Method)
at java.base/sun.nio.ch.Net.connect(Unknown Source)
at java.base/sun.nio.ch.NioSocketImpl.connect(Unknown Source)
at java.base/java.net.SocksSocketImpl.connect(Unknown Source)
at java.base/java.net.Socket.connect(Unknown Source)
at org.apache.http.conn.socket.PlainConnectionSocketFactory.connectSocket(PlainConnectionSocketFactory.java:75)
at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:142)
at org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:374)
at org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:393)
at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:236)
at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:186)
at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:89)
at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:110)
at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:185)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:83)
at org.eclipse.ecf.provider.filetransfer.httpclient45.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:248)
at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:71)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
How can I fix this issue? Any ideas ?
Would be very grateful!!
Re: Installation Error [message #1833661 is a reply to message #1833647] Tue, 20 October 2020 10:45 Go to previous messageGo to next message
This is like this post:
https://www.eclipse.org/forums/index.php?t=msg&th=1104995&goto=1831643&#msg_1831643
There I asked"Is this problem consistently reproducible?" but got no answer...
A Google search of "java.net.SocketException: Address family not supported by protocol family: connect" suggests this could be caused by a firewall blocking communication, but I got no answer to that either.
If you can't get it to work, download a package from here instead:
Re: Installation Error [message #1833662 is a reply to message #1833661] Tue, 20 October 2020 11:39 Go to previous messageGo to next message
I searched for a solution by googling "java.net.SocketException: Address family not supported by protocol family: connect" and found that you can paste "setx _JAVA_OPTIONS -Djava.net.preferIPv4Stack=true" in the cmd, but that didnt work aswell. Afterwards I tried to install it several times and it showed me the same log. If there is no solution for that issue, how exactly do I install eclipse, when I downloaded a package ?
Thank you very much!!
Re: Installation Error [message #1833663 is a reply to message #1833662] Tue, 20 October 2020 13:50 Go to previous message
Thank you for answering! Have you tried disabling your antivirus/firewall temporarily?
Another thing I would appreciate if you tried this version of the installer:
http://www.eclipse.org/downloads/download.php?file=/oomph/products/eclipse-inst-jre-win64.exe
It has a newer JRE version in it (and that JRE has an additional module to properly support https protocol), so it would be very helpful if you could try that newer version.
Failing that you can download the *.zip from here and unzip it into some folder:
Previous Topic:Eclipse Oxygen won't start
Next Topic:Eclipse 2020-09 crashes repeatedly, errors with multiple plugins
Current Time: Tue Jul 22 04:12:01 EDT 2025
Powered by FUDForum. Page generated in 0.16816 seconds
