Home » Archived » BIRT » Custom data source(How do I use the contents of a text file as a data source?)
Custom data source [message #1833484] Wed, 14 October 2020 09:39 Go to next message
We have a requirement to take the complete contents of a multi-line text file, and put it into a cell in a BIRT report.
Unfortunately, I cannot manipulate the text file before the BIRT engine gets it. Otherwise I could wrap it in XML tags and make BIRT react to it as an XML data source.
Is there any easy way of achieving this?
Thanks in advance
Phil
Re: Custom data source [message #1833614 is a reply to message #1833484] Mon, 19 October 2020 16:51 Go to previous messageGo to next message
You should be able to use csv or excel also. Just need a source that BIRT can read.
Re: Custom data source [message #1833634 is a reply to message #1833614] Tue, 20 October 2020 03:03 Go to previous message
Hi Robert
Thanks for the reply. You're right, I need a source that BIRT can read. The complete contents of an unstructured text file doesn't seem to qualify.
Cheers
Phil
Previous Topic:Creating Data Set sort Available Fields box
Next Topic:Creating Data Set sort Available Fields box
Current Time: Sun Jul 20 21:47:09 EDT 2025
Powered by FUDForum. Page generated in 0.29024 seconds
