Re: Instances of Exchange Items [message #1833606 is a reply to message #1833475] |
Mon, 19 October 2020 13:28  |
Thanks for the response Juan!
That exact procedure is possible also with functional chains although the [display] "Exchange Context" accelerator for functional chain description diagrams is missing. I was able to around this but I had to load the exchange context in the diagram as a regular constraint. (functional chain involvement links also have the "Exchange Context" field so it is possible to create the constraint, the only thing missing is the accelerator to properly bring the representation to the diagram - with the "Constraints" accelerator I'm able to bring the constraint but without the proper link).
The difficulty I have is with defining the Exchange Item instance, I could use the ctrl-space to properly reference the ExchangeItem but I'm not able to specify the properties within the exchange item as an instance in the CDB so that I can reference the specific instance - notice, it is not a big issue for me, I just wanted to know if it was possible since there seemed to be provisions for that: I've noticed I can add an "Exchange Instance" on the Exchange Item in the Project Explorer but it does not enable me to specify properties based on the definition of the exchange item.
Thanks again for the time taken reading and answering this
FUDForum. Page generated in 0.04589 seconds
