eclipse 2020-06 and PyDev crash [message #1833417] |
Mon, 12 October 2020 12:05  |
I recently downloaded this file to install eclipse:
eclipse-cpp-2020-06-R-linux-gtk-x86_64.tar.gz
As I jave JDK 8 I do not want to go to 2020-09 and above.
1. I start eclipse and create a new workspace
2. I install pydev
3. I restart eclipse
-> Crash.
I see a graphical popup now everytime I restart eclipse.
In the logile here:
/home/boerns/eclipse-workspace/python/.metadata/.log
I see this:
Content of file:
!SESSION 2020-10-12 17:51:42.829 -----------------------------------------------
eclipse.buildId=4.16.0.I20200604-0540
java.version=1.8.0_265
java.vendor=Gentoo
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=de_DE
Framework arguments: -product org.eclipse.epp.package.cpp.product
Command-line arguments: -data file:/home/boerns/eclipse-workspace/python/ -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.cpp.product
!ENTRY org.eclipse.e4.ui.workbench 4 0 2020-10-12 17:51:47.679
!MESSAGE Unable to load resource file:/home/boerns/eclipse-workspace/python/.metadata/.plugins/org.eclipse.e4.workbench/workbench.xmi
!STACK 0
at org.eclipse.e4.ui.internal.workbench.ResourceHandler.getResource(ResourceHandler.java:287)
at org.eclipse.e4.ui.internal.workbench.ResourceHandler.loadResource(ResourceHandler.java:263)
at org.eclipse.e4.ui.internal.workbench.ResourceHandler.loadMostRecentModel(ResourceHandler.java:169)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.loadApplicationModel(E4Application.java:384)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:260)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:579)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:557)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:154)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:150)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
at org.eclipse.equinox.launcher.Main.run(Main.java:1447)
at org.eclipse.equinox.launcher.Main.main(Main.java:1420)
!ENTRY org.eclipse.e4.ui.workbench 4 0 2020-10-12 17:51:47.680
!MESSAGE The persisted application model has no top-level window. Reinitializing with the default application model.
!STACK 0
java.lang.Exception
at org.eclipse.e4.ui.internal.workbench.ResourceHandler.loadMostRecentModel(ResourceHandler.java:174)
!MESSAGE Unable to load resource platform:/plugin/org.eclipse.platform/LegacyIDE.e4xmi
!STACK 0
at org.eclipse.e4.ui.internal.workbench.ResourceHandler.loadMostRecentModel(ResourceHandler.java:181)
!ENTRY org.eclipse.tools.templates.freemarker.java11 2 0 2020-10-12 17:51:47.793
!MESSAGE Could not resolve module: org.eclipse.tools.templates.freemarker.java11 [470]
Unresolved requirement: Fragment-Host: org.eclipse.tools.templates.freemarker; bundle-version="1.0.0"
!ENTRY org.eclipse.osgi 4 0 2020-10-12 17:51:47.799
!MESSAGE Application error
!STACK 1
at org.eclipse.e4.ui.internal.workbench.ResourceHandler.loadMostRecentModel(ResourceHandler.java:182)
!SESSION 2020-10-12 17:55:17.446 -----------------------------------------------
java.vendor=Gentoo
Command-line arguments: -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.cpp.product
!ENTRY org.eclipse.e4.ui.workbench 4 0 2020-10-12 17:55:27.686
!STACK 0
!ENTRY org.eclipse.e4.ui.workbench 4 0 2020-10-12 17:55:27.687
!STACK 0
java.lang.Exception
!STACK 0
!ENTRY org.eclipse.tools.templates.freemarker.java11 2 0 2020-10-12 17:55:27.734
!ENTRY org.eclipse.osgi 4 0 2020-10-12 17:55:27.734
!STACK 1
Re: eclipse 2020-06 and PyDev crash [message #1833426 is a reply to message #1833417] |
Mon, 12 October 2020 17:27  |
Whether you want to go to 2020-09 or not is irrelevant. It's the supported release, and you somehow seem to have
plug-ins installed that need Java 11, just like 2020-09. You might also have some filesystem corruption happening
if /home/boerns/eclipse-workspace/python/.metadata/.plugins/org.eclipse.e4.workbench/workbench.xmi is
unreadable.
FUDForum. Page generated in 0.10217 seconds
