Home » Polarsys » Capella General » Difference between deploying Node PC and declaring parent
Difference between deploying Node PC and declaring parent [message #1833335] Fri, 09 October 2020 07:05 Go to next message
In the physical architecture, it seems I in Capella 1.4.1 is able to both deploy a PC on another PC, and declare one PC as component of another PC.
Is there a difference?
Re: Difference between deploying Node PC and declaring parent [message #1833357 is a reply to message #1833335] Sat, 10 October 2020 13:12 Go to previous messageGo to next message
Hi Asmund,
Have you looked at this pat of the Capella 1.4 webinar? https://www.youtube.com/watch?v=AhRpOjfyPbk&t=875s
Not sure it answers completely your question though..
Stephane
Re: Difference between deploying Node PC and declaring parent [message #1833471 is a reply to message #1833357] Wed, 14 October 2020 04:29 Go to previous messageGo to next message
Thank you for the pointer, that explains it well and answers my question. You deploy behaviours on physical nodes, but physical nodes are part of each-other.
I am not fully onboard on the need for the strong distinction between node that have behaviour, and nodes that do not. An adjustable wall in a flotation unit, or fixed overflow channel in a dam vs control valve. A chute vs transportation screw? I guess it ends up being modelers choice, but I am not that experienced yet....
Re: Difference between deploying Node PC and declaring parent [message #1834776 is a reply to message #1833471] Tue, 17 November 2020 11:39 Go to previous message
You may have a look to this similar post: https://www.eclipse.org/forums/index.php/t/1105080/
Previous Topic:Capturing Physical Links as a group in Physical Architecture
Next Topic:ARCADIA documents outputs
Current Time: Wed Nov 05 10:51:46 EST 2025
Powered by FUDForum. Page generated in 0.06269 seconds
