Home » Newcomers » Newcomers » java.lang.ExceptionInInitializerError 32 bit RCP application(32 bit JDK 8u261 on RCP gives Caused by: java.lang.IllegalArgumentException: Invalid version number: Version number may be negative or greater than 255)
java.lang.ExceptionInInitializerError 32 bit RCP application [message #1833251] Wed, 07 October 2020 12:56 Go to next message
We have a 32 bit RCP application which works fine with jdk1.8.0_211 or below.
But when we use jdk1.8.0_261 it gives java.lang.ExceptionInInitializerError while launching the application.
ie. (-vm C:\Program Files (x86)\Java\jdk1.8.0_261\jre)
The complete error is :
at com.ibm.icu.text.Collator.<clinit>(Collator.java:946)
at org.eclipse.ui.internal.WorkingSetComparator.<init>(WorkingSetComparator.java:29)
at org.eclipse.ui.internal.WorkingSetComparator.<clinit>(WorkingSetComparator.java:27)
at org.eclipse.ui.internal.AbstractWorkingSetManager.<init>(AbstractWorkingSetManager.java:79)
at org.eclipse.ui.internal.WorkingSetManager.<init>(WorkingSetManager.java:46)
at org.eclipse.ui.internal.WorkbenchPlugin.getWorkingSetManager(WorkbenchPlugin.java:608)
at org.eclipse.ui.internal.Workbench.getWorkingSetManager(Workbench.java:1262)
at org.eclipse.ui.internal.WorkbenchPage.restoreState(WorkbenchPage.java:3122)
at org.eclipse.ui.internal.WorkbenchWindow.restoreState(WorkbenchWindow.java:2102)
at org.eclipse.ui.internal.Workbench.doRestoreState(Workbench.java:3357)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.java:2075)
at org.eclipse.ui.internal.Workbench.access$28(Workbench.java:2060)
at org.eclipse.ui.internal.Workbench$48.run(Workbench.java:1923)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.java:1867)
at org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(WorkbenchConfigurer.java:183)
at org.eclipse.ui.application.WorkbenchAdvisor$1.run(WorkbenchAdvisor.java:781)
at com.ibm.icu.util.VersionInfo.getInstance(VersionInfo.java:191)
at com.ibm.icu.impl.ICUDebug.getInstanceLenient(ICUDebug.java:65)
at com.ibm.icu.impl.ICUDebug.<clinit>(ICUDebug.java:69)
... 17 more
What could be the issue ?
- Subhash
Re: java.lang.ExceptionInInitializerError 32 bit RCP application [message #1833263 is a reply to message #1833251] Thu, 08 October 2020 02:24 Go to previous messageGo to next message
I really don't know what the developers are thinking with this code:
     * Returns an instance of VersionInfo with the argument version.
     * @param major major version, non-negative number &lt;= 255.
     * @param minor minor version, non-negative number &lt;= 255.
     * @param milli milli version, non-negative number &lt;= 255.
     * @param micro micro version, non-negative number &lt;= 255.
     * @exception IllegalArgumentException when either arguments are negative or &gt; 255
     * @stable ICU 2.6
    public static VersionInfo getInstance(int major, int minor, int milli,
                                          int micro)
        // checks if it is in the hashmap
        // else
        if (major < 0 || major > 255 || minor < 0 || minor > 255 ||
            milli < 0 || milli > 255 || micro < 0 || micro > 255) {
            throw new IllegalArgumentException(INVALID_VERSION_NUMBER_);
I.e., I'm not sure why any of the version segments can't be greater then 255...
It's not as if you're the first person to encounter this:
https://stackoverflow.com/questions/61462535/jasypt-encryption-stops-working-after-upgrade-to-jdk-7u261
I don't see any open bug reports about it...
Re: java.lang.ExceptionInInitializerError 32 bit RCP application [message #1833287 is a reply to message #1833263] Thu, 08 October 2020 08:45 Go to previous messageGo to next message
I am sorry I coudn't follow. Our problem is , when the customer applies latest jre (JDK 8u261) then it gives the the I have mentioned. Our application is a 32 bit RCP application. So is there any version limt for any RCP application for supported jre ?
- Subhash
Re: java.lang.ExceptionInInitializerError 32 bit RCP application [message #1833291 is a reply to message #1833263] Thu, 08 October 2020 09:13 Go to previous messageGo to next message
So what you suggest ? Use another version or jre ?? Can you please advice ?
Re: java.lang.ExceptionInInitializerError 32 bit RCP application [message #1833295 is a reply to message #1833291] Thu, 08 October 2020 10:04 Go to previous messageGo to next message
From what I can tell of the code for any JRE version 1.8.0.256 or higher would have a problem like this. :-( I just don't get the point of such a guard...
Re: java.lang.ExceptionInInitializerError 32 bit RCP application [message #1833298 is a reply to message #1833295] Thu, 08 October 2020 10:23 Go to previous messageGo to next message
Ok, thanks Ed Merks.
Re: java.lang.ExceptionInInitializerError 32 bit RCP application [message #1833302 is a reply to message #1833295] Thu, 08 October 2020 10:51 Go to previous messageGo to next message
Ed,
That means we can't use jre 8 with version more that 255 ? What I have found is from jre 9 onwards there is no support for 32 bit. If that is the case, then we hit the road block. Our Eclipse RCP is 32 bit application. ...
Any thought ?
- Subhash
Re: java.lang.ExceptionInInitializerError 32 bit RCP application [message #1833303 is a reply to message #1833302] Thu, 08 October 2020 11:24 Go to previous messageGo to next message
Yes, it seems 32 bit has reach end of life. Is there some native things you're using that require 32 bit and don't have corresponding 64 bit version? I.e., why do you need 32 bit?
Re: java.lang.ExceptionInInitializerError 32 bit RCP application [message #1833411 is a reply to message #1833303] Mon, 12 October 2020 09:46 Go to previous messageGo to next message
Ed,
We have an old RCP product built on 32 bit and rolled out to customers. Is there any option to maintain this product without migrating to 64 since there is no developers working on maintenance ?
Now customers for security reason use new versions of jre and it fails due to the version number check with in.
- Subhash
Re: java.lang.ExceptionInInitializerError 32 bit RCP application [message #1833433 is a reply to message #1833411] Tue, 13 October 2020 01:49 Go to previous message
I really don't know what to suggest. It looks like it's parsing the value of the "java.version" system property (mostly to decide if it's Java 1.4 or higher) so maybe you could somehow set that system property, at least while initializing, i.e., during a call to com.ibm.icu.text.Collator.getInstance() very early in your application.
Previous Topic:eclipse 2020-06 and PyDev crash
Next Topic:Eclipse 2020-09 fails to find plug-in sources on Linux
Current Time: Sun Jul 27 16:32:15 EDT 2025
Powered by FUDForum. Page generated in 0.10290 seconds
