Home » Modeling » TMF (Xtext) » java.io.FileNotFoundException
java.io.FileNotFoundException [message #1833189] Tue, 06 October 2020 06:02 Go to next message
recently i have installed eclipse Version: 2019-12 (4.14.0) with Build id: 20191212-1212 . The Xtext plugin is 2.20.0.v20191202-1256
On the creation of a new xtext project i select the web integration support and gradle as prefered build system.
The artifacts of the hello world example language are generated successful. The problem comes after i try to run the jetty server.
The following message appears on the console log .
[main] INFO org.eclipse.jetty.util.log - Logging initialized @235ms to org.eclipse.jetty.util.log.Slf4jLog
[main] INFO org.eclipse.jetty.server.Server - jetty-9.4.22.v20191022; built: 2019-10-22T13:37:13.455Z; git: b1e6b55512e008f7fbdf1cbea4ff8a6446d1073b; jvm 1.8.0_261-b12
[main] WARN org.eclipse.jetty.webapp.WebAppContext - Failed startup of context o.e.j.w.WebAppContext@29774679{/,file:///C:/Users/michael/Desktop/eclipse201912/WorkspaceServer/org.xtext.example.mydsl.parent/org.xtext.example.mydsl.web/WebRoot/,UNAVAILABLE}
java.io.FileNotFoundException: C:\org.xtext.example.mydsl.web\bin\default (The system cannot find the path specified)
	at java.util.zip.ZipFile.open(Native Method)
	at java.util.zip.ZipFile.<init>(Unknown Source)
	at java.util.jar.JarFile.<init>(Unknown Source)
	at sun.net.www.protocol.jar.URLJarFile.<init>(Unknown Source)
	at sun.net.www.protocol.jar.URLJarFile.getJarFile(Unknown Source)
	at sun.net.www.protocol.jar.JarFileFactory.get(Unknown Source)
	at sun.net.www.protocol.jar.JarURLConnection.connect(Unknown Source)
	at sun.net.www.protocol.jar.JarURLConnection.getJarFile(Unknown Source)
	at org.eclipse.jetty.webapp.MetaInfConfiguration.getTlds(MetaInfConfiguration.java:445)
	at org.eclipse.jetty.webapp.MetaInfConfiguration.scanForTlds(MetaInfConfiguration.java:361)
	at org.eclipse.jetty.webapp.MetaInfConfiguration.scanJars(MetaInfConfiguration.java:172)
	at org.eclipse.jetty.webapp.MetaInfConfiguration.preConfigure(MetaInfConfiguration.java:101)
	at org.eclipse.jetty.webapp.WebAppContext.preConfigure(WebAppContext.java:488)
	at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:523)
	at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:72)
	at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:169)
	at org.eclipse.jetty.server.Server.start(Server.java:407)
	at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:110)
	at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:106)
	at org.eclipse.jetty.server.Server.doStart(Server.java:371)
	at org.xtext.example.mydsl.web.ServerLauncher.main(ServerLauncher.java:47)
[main] INFO org.eclipse.jetty.server.AbstractConnector - Started ServerConnector@64b8f8f4{HTTP/1.1,[http/1.1]}{localhost:8080}
[main] INFO org.eclipse.jetty.server.Server - Started @828ms
[main] INFO org.xtext.example.mydsl.web.ServerLauncher - Server started http://localhost:8080/...
[Thread-8] INFO org.xtext.example.mydsl.web.ServerLauncher - Press enter to stop the server...
This is the ServerLauncher.xtend file produced by xtext
 * generated by Xtext 2.20.0
package org.xtext.example.mydsl.web
import java.net.InetSocketAddress
import org.eclipse.jetty.annotations.AnnotationConfiguration
import org.eclipse.jetty.server.Server
import org.eclipse.jetty.util.log.Slf4jLog
import org.eclipse.jetty.webapp.MetaInfConfiguration
import org.eclipse.jetty.webapp.WebAppContext
import org.eclipse.jetty.webapp.WebInfConfiguration
import org.eclipse.jetty.webapp.WebXmlConfiguration
 * This program starts an HTTP server for testing the web integration of your DSL.
 * Just execute it and point a web browser to http://localhost:8080/
class ServerLauncher {
	def static void main(String[] args) {
		val server = new Server(new InetSocketAddress('localhost', 8080))
		server.handler = new WebAppContext => [
			resourceBase = 'WebRoot'
			welcomeFiles = #["index.html"]
			contextPath = "/"
			configurations = #[
				new AnnotationConfiguration,
				new WebXmlConfiguration,
				new WebInfConfiguration,
				new MetaInfConfiguration
			setAttribute(WebInfConfiguration.CONTAINER_JAR_PATTERN, '.*/org\\.xtext\\.example\\.mydsl\\.web/.*,.*\\.jar')
			setInitParameter("org.mortbay.jetty.servlet.Default.useFileMappedBuffer", "false")
		val log = new Slf4jLog(ServerLauncher.name)
		try {
			server.start
			log.info('Server started ' + server.getURI + '...')
			new Thread[
				log.info('Press enter to stop the server...')
				val key = System.in.read
				if (key != -1) {
					server.stop
				} else {
					log.warn('Console input is not available. In order to stop the server, you need to cancel process manually.')
			].start
			server.join
		} catch (Exception exception) {
			log.warn(exception.message)
			System.exit(1)
As expexted after visiting http://localhost:8080 i get the following error HTTP ERROR 503 Service Unavailable
Is this a bug ?
Re: java.io.FileNotFoundException [message #1833190 is a reply to message #1833189] Tue, 06 October 2020 06:08 Go to previous messageGo to next message
do you have proper gradle tooling installed in eclipse? if yes the we project src folders should be configured like shown in the image. there also should not be any errors oin any of the projects
and then eclipse shoulft not check bin default
can you check the buildship version?
[Updated on: Tue, 06 October 2020 06:09] by Moderator
Re: java.io.FileNotFoundException [message #1833191 is a reply to message #1833190] Tue, 06 October 2020 06:12 Go to previous messageGo to next message
ps: you can also run the jettyRun goal from gradle
Re: java.io.FileNotFoundException [message #1833193 is a reply to message #1833191] Tue, 06 October 2020 06:45 Go to previous messageGo to next message
Hi Christian
My projects src folders build path configuration is exactly the same as shown in the image. Also no errors are present in any of my projects.
I haven' t installed inside eclipse any extra toolchain for the building system .
I use the build ship provided by the official release of this eclipse version.
The build ship information is the following
Eclipse Buildship Buildship, Eclipse Plug-ins for Gradle 3.1.3.v20191118-1057 org.eclipse.buildship
i have also installed Gradle version 6.6.1. in my pc
After running thru the console the jetty Server, i don't get any errors at all.
Should i update the build ship inside eclipse ? And if yes witch version is preferable ?
Thanks again
[Updated on: Thu, 20 May 2021 10:59] by Moderator
Re: java.io.FileNotFoundException [message #1833194 is a reply to message #1833193] Tue, 06 October 2020 07:05 Go to previous messageGo to next message
i dont know why the bin default is NOT on classpath in my code but is on yours.
can be a buildship problem or a project config problem or something else.
how does your .classpath file look like?
unfortunately i dont have a xtext 2.20 at hand to test
Re: java.io.FileNotFoundException [message #1833196 is a reply to message #1833194] Tue, 06 October 2020 07:35 Go to previous message
I have uploaded 2 png files.
The classPath.png shows my current build Path setup of my source
The gradle.png shows my selection for the Gradle build ship used in the eclipse
After selecting the Local installation directory the problem disappears.
Hope this was the issue !!!
  • Attachment: classPath.png
    (Size: 71.77KB, Downloaded 125 times)
  • Attachment: gradle.png
    (Size: 47.59KB, Downloaded 112 times)
Previous Topic:Integrate Kotlin src-dependencies into the workflow with gradle
Next Topic:Separating New Wizards and File Templates
Current Time: Mon Jul 21 09:26:49 EDT 2025
Powered by FUDForum. Page generated in 0.06590 seconds
